fishing poles
- dcwuk
fishing poles
I am thinking of putting up a trapped dipole of approx 54 feet in length.
Fixing at the house end of the garden is not a problem but at the other end there is only a perimeter fence and i am wondereing wheter i could use a 7-8m fishing pole to support the dipole or will it bend too much.
I know that some people use a alloy pole with a fishing pole on top.
Opinions and suggestions please gentleman and ladies if present
regards
dcw
regards
dcw
- fez
Re: fishing poles
You can use one but not all of it. You may only be able to use it half the pole as it will become too bendy.
- northern35s
Re: fishing poles
A full length fishing pole will bend a lot, whether it is too much depends on how you construct your dipole, but with it being trapped I would venture that the fishing pole isn't up to the job. Why not invest in a 20' scaffold pole, a good guy rope, and some isolators, that should do the trick.
Mobile DXing from the car and on foot
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: fishing poles
or off-set it from the end of the garden and use a guy line to the perimiter fence. :-)
- nordhavn
Re: fishing poles
I use roofing batons , not as long as fishing poles but you can screw them to walls etc . & i bought a bundle of 20 for £4 something .
- dcwuk
Re: fishing poles
That where my thinking was going, getting a 10m pole for example but only using 6-7m of it.fez wrote:You can use one but not all of it. You may only be able to use it half the pole as it will become too bendy.
Appreciate yours and others input
I need to get the aerial at approx 25m so maybe an alloy pole and a fishing pole on top?
I have a hustler vertical which i could use at ground level but i am in two minds about it and the need to for ground radials in the small area i have to work in.
I expect i will put both of them up and see how i get on.
cheers
dcw
- fez
Re: fishing poles
have a look at the ex military fibreglass masts, Cost about £50. I think they are about 5m tall.
http://cgi.ebay.co.uk/CLANSMAN-MILITARY ... 518a28841d
http://cgi.ebay.co.uk/CLANSMAN-MILITARY ... 230548dc38
http://cgi.ebay.co.uk/CLANSMAN-MILITARY ... 51905efef0
come with guy ropes, spikes and rings.
I have a set here and they are great.
- dcwuk
Re: fishing poles
Thanks for the links, another option for me to ponder
Re: fishing poles
Ooh nice Fez, not seen those before.
Im using about 5 meters of a 10m pole for my inverted L and its pretty solid. You can tape the joints too if you plan on leafing it up for any length of time. The other 5 meters is currently holding the middle of it up until i can get up on the roof and fix up a pulley to the chimney to putt it up proper.
M6JCA -> 2E0JCA
Yaesu FT-897, FT-857D (In car), FT-817D & Wouxun KG-UVD1P
Full wave 40M wire loop for HF, Watson V2000 for 2, 70 & 6
HRD Logbook: http://www.hrdlog.net/ViewLogbook.aspx?user=2E0JCA
- dcwuk
Re: fishing poles
Thanks Jamesa
I am having a look at all my options now,those military masts do look tempting though.
regards
dcw
regards
dcw
- Black_Pirate
- Call Sign: 26TM034
Re: fishing poles
i would try the fishing pole just dont us e the last 2 sections if you want it more solid spray some gap filler down it and let it set solid job done . . How about a sea rod frm a car boot ? 10 quid job done
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
Re: fishing poles
What about this - http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Maybe only good enough to support a centre fed wire dipole ?
M0PCZ - Paul
Kenwood TS-480SAT
ZS6BKW 91' multi band dipole.
Icom IC-706/monoband whip's.
Sirio 827 5/8 Vertical
http://www.facebook.com/profile.php?id=100002696240300
http://www.facebook.com/pages/Ham-Radio ... 4980872231
Kenwood TS-480SAT
Re: fishing poles
i use a windsurfer pole aquired off freecycle comes in 2 pieces with a glass pole on top and a wheel rim in the bush to locate the base and stop it kicking out comes down easily
