Not getting the results with inverted v on 11mtrs ,advice
original45
Call Sign: 45
Post by original45 » 27 Mar 2019, 16:31
I have made a couple now, found 8'3" about the ideal length and the swr on the v doesn't hardly move the needle on the meter 0 across uk 40
So sounds good.
Stick it up suspended from a fibreglass rod some 11 ft to tip ,bring each leg out to between 90-120 degree
Coax is good ,old but good ,good plugs.
Using the eurosonic es 200 which is giving 4watts.
Checked the lot out best I know
So for days I have been on highest point locally 360 mtrs to try a contact with a friend in Coventry ,some 25miles as crow flies.
I hear him v loud I guess signal 6/7 great audio however considering my height I am unable to make the contact on 11mtrs.
I today heard others around atherstone simular distance,strong audio ,they heard me cq but couldn't make my audio out.
The antenna receives fantastically ,I had many weak signals on a dozen channels obviously a good distance but I'm not making the return.
I even tried altering leg direction ?
Any thoughts ,advice for improvements to the v , ???.
I havnt a pole to try a t2lt type yet either but hear too their only just ok.
Lastly recommendations for a better wire please.
Just to add ,the same position time I then made a contact with my friend 25miles away easily with the uv5r and counterpoise wire attached to belt clip. Perfect audio strong signal and we both were using the factory antenna ,both standing outside he wasn't on a base antenna then either .
I just don't get it .
Help
DX-Digger
Call Sign: TM205
Re: Not getting the results with inverted v on 11mtrs ,advice
Post by DX-Digger » 27 Mar 2019, 19:53
Try mounting it vertical as most are running vertical polarisation and with power.
or try making a T2LT and see how you get on with that. very cheap antenna made from coax
Cheers Mark
Post by ch25 » 27 Mar 2019, 21:03
1. Where is resonance? SWR is less important.
2. Where is current balun?
It is horizontal, omnidirectional antenna. Big loss against vertical transmitting stations on ground wave. For CB local contacts you need vertical antenna.
original45
Call Sign: 45
Post by original45 » 27 Mar 2019, 21:34
Oh Chris, God bless ya ,resonance I have no idea I wouldn't know how to tell.
Their is no current balun either what ever that is ,I'm guessing not a rf choke.
I will try it vertical too.
Obviously I made it wrong .
Grrrrrr
Post by ch25 » 27 Mar 2019, 21:45
Sad to say, but totally wrong. First of it all you need vertical polarised antenna. Inv V is not.
original45
Call Sign: 45
Post by original45 » 27 Mar 2019, 21:59
Ok I have marks recommendation of the T2LT antenna thank you mark , have you one Chris please that will be a easy build and work v well please.
Thanks again as ever honest reply .
Appreciated
Post by ch25 » 27 Mar 2019, 23:09
Play with garbage, get garbage results...
Just build 1/4 GP, simple and effective.
