YAESU FRG -7700 RECEVER
Andy-in-NL
Call Sign: 9TC02
Re: YAESU FRG -7700 RECEVER
Post by Andy-in-NL » 12 Sep 2015, 19:06
Did you get that selector switch problem worked out?
Post by Admiral » 12 Sep 2015, 23:38
And again, speaking as a non-techie, I'm not too sure that you can see a diode leaking with a magnifying glass.
gerald123
Post by gerald123 » 12 Sep 2015, 23:49
it sorted it self out .... the more i used the radio the better it got ,it is now working fine.......
Andy-in-NL
Call Sign: 9TC02
Post by Andy-in-NL » 20 Sep 2015, 20:39
gerald123 wrote:it sorted it self out .... The more I used the radio the better it got ,it is now working fine.......
Sounds like corrosion onthe contacts that cleaned up after several uses. Sometimes a little film of crap gets on the contacts from lack of use. Using that button vigoriously solves that isse. Congrats.
andymuza
Post by andymuza » 21 Sep 2015, 14:42
Does the time it takes to change stay constant or does it get slower or faster the longer the radio is turned on for?
mickfitzer
Call Sign: 29SF332
Post by mickfitzer » 26 Aug 2016, 06:49
Glad that you got radio sorted after gerard123, Also if you are ever looking to shift the radio count me in for £30 lol got a soft spot for these old receivers
VX5R
Call Sign: M3swl
Post by VX5R » 02 Apr 2017, 08:47
I'm watching one on eBay now
Yaesu VX5R
Yaesu VX6R for tx
Yupiteru MVT7100
Realistic pro-2042
Op... Tim.
M3swl
ROTEL240
Post by ROTEL240 » 02 Apr 2017, 13:55
I have one for sale and its in good condition for its age and works as it should.
Bernard Rother
Post by Bernard Rother » 04 May 2017, 11:37
Also have a FRG 7700 but it's been in the roof for a good few years as we live in a horse shoe shaped valley. Don't even receive local radio stations anymore as the vegetation has become more dense over time. BUT ....... as some of you may have read, I bought a damaged CB 27MHz radio last Friday. Got it going but had nobody to chat to in order to confirm if it was working. Checked up on the FRG's frequencies and the CB range fell in with those. Hauled it down, the roof is totally insulated so there is no damp or dust present etc.....just nice and warm up there.
OK .... the CB and the FRG were pretty close to each other .... both with a simple wire for antennas in the interim. The FRG picked up the CB first go. It now has a temporary place in my lounge. Image
