YAESU FRG -7700 RECEVER
gerald123
Post by gerald123 » 01 Nov 2014, 00:41
hi lads ,just got my self one of the abouve recevers......my problem is the band selector. as an example, if i select 5 it shows 3 for about ten seconds, then goes to 5 but it is a pain just waiting for it to change.....HELP {bnghd}
Re: YAESU FRG -7700 RECEVER
Post by Admiral » 01 Nov 2014, 13:19
Have you tried switch cleaner on the band selector?
Sorry, best input I can offer as a non-techie.
gerald123
Post by gerald123 » 01 Nov 2014, 14:36
Admiral wrote:Have you tried switch cleaner on the band selector?
gerald123
Post by gerald123 » 01 Nov 2014, 20:54
thanks for that ,but yes I have tried switch cleaner.....no joy
ChrisCSL
Banned
Banned
Post by ChrisCSL » 01 Nov 2014, 21:18
So ... the person you bought it off.
Did it do the same for him?
gerald123
Post by gerald123 » 01 Nov 2014, 21:41
yes it did the same for him. just thought it would be a easy fix .for 30 pounds pluss postage ........not bad I thought there is not a mark on it, and it looks like new good audio, 12 channel memory fitted...just that one problem with switch.
ChrisCSL
Banned
Banned
Post by ChrisCSL » 01 Nov 2014, 22:12
gerald123 wrote:yes it did the same for him. just thought it would be a easy fix .for 30 pounds pluss postage ........not bad I thought there is not a mark on it, and it looks like new good audio, 12 channel memory fitted...just that one problem with switch.
Fair enough. So at least he must have been honest, and you bought it with an annoying minor fault.
30 quid isn't bad, they were a nice reciever in the day.
gerald123
Post by gerald123 » 02 Nov 2014, 00:02
yes like I said it is working great...I am just hoping some one will come on here and tell me how to correct the fault ....... :idea: please
26TM944
Call Sign: 26TM944
Post by 26TM944 » 02 Nov 2014, 06:45
Hi,
These are proper old now but have a look around the MC14504 as it's likely to be flaky, the bands are selected by BCD and there are a fair amount of discrete components on the board that can by now have aged to a point where they are no longer stable, leaky diodes and the like. You've got the MB8718 which sits after the level converter, that could be getting moody as well.
Have you done any poking about with a knitting needle to see if anything responds to movement? Does the radio vary in frequency when the fault appears or only the counter?
There was a scrapper on ebay a while ago if still about might be good for spares and of course https://groups.yahoo.com/neo/groups/FRG-7700/info is going to be a goldmine for info
Good luck.
Steve
26-TM-944
  • A rig, twig & burner.
gerald123
Post by gerald123 » 02 Nov 2014, 12:44
26TM944 wrote:Hi,
Good luck.
Steve
gerald123
Post by gerald123 » 02 Nov 2014, 13:11
thanks ,steve no I have not opened it yet because I did not know what to look for, but now I will ........ where abouts on the board is the [ MC14504 ] is it clearly marked........the frequencie is stable but like I said for example if the band selector in on 5 MHz and you then select 6 MHz it takes about 10 seconds if not more to change. but when it changes it is stable.
gerald123
Post by gerald123 » 03 Nov 2014, 19:14
26TM944 wrote:Hi,
Good luck.
Steve
thanks for the link steve :thumbup:
gerald123
Post by gerald123 » 03 Nov 2014, 23:49
hi, checked all inside the radio with a magnifying glass every thing seems ok no leaking diodes no dirt no flaking mci4504 it is all like new as far as I can see. had a look to see if anything loose ......nothing responding to movement....
bigbassman
Post by bigbassman » 05 Nov 2014, 21:10
1 X PRO 2006 1 X DX-394 1 X GRE PSR 282 1 X UBC780XLT with ProScan 1 X Pro43 2 X Uniden UBC9000XLT Tristar777 LCL 2740.
gerald123
Post by gerald123 » 05 Nov 2014, 22:21
thanks for that bigbassman
