Mini Whip.
- Call Sign: M1ZXZ
Mini Whip.
With regards to the PA0RDT mini whip..
Does anybody use this.. wandering if it really does perform as well as it claims to be ?
I'me thinking about installing one on the chimney stack, well away from household noise etc.
Being an omnidirectional antenna, I'me thinking it may be worthwhile..
Radio World sell them for £99.00
Thanks..
Thanks..
- Admiral
- Call Sign: 26TM157
Re: Mini Whip.
I have no idea.
But, if you're okay with an iron, why not build your own for a lot less than a ton?
http://www.schripsema.org/pa3hdf/projec ... _whip.html
- crusty
Re: Mini Whip.
In my experience they're noise magnets when used in built-up areas. Work well in electrically quiet locations away from buildings/houses. A T2FD or active wideband loop is much better choice unless you live in the countryside.M1ZXZ wrote:With regards to the PA0RDT mini whip..
Thanks..
£99.00 is a rip-off. Its a very basic design with a low part count.
- Call Sign: 26TM577
Re: Mini Whip.
There is a guy from Poland sells the pcbs including the power feed pcb on Ebay, I've just built one total cost inc waterproof enclosure about £15. Just need to get it up on a pole now...
UBC 3500xlt Pro 2006 GRE PSR 295 AR8000
Yaesu FRG7 Tecsun PL660 AKD HF3E Zastone ZT-2R
Superstar 360
Superstar 360
- Admiral
Re: Mini Whip.
Any chance of a link please gosman? I searched for PA0RDT on eBay Poland and just got a load of Fiat spare parts.gosman767 wrote:There is a guy from Poland sells the pcbs including the power feed pcb on Ebay, I've just built one total cost inc waterproof enclosure about £15. Just need to get it up on a pole now...
For £15 I'd quite fancy a go at that, gotta be better to hang out of a hotel window than a telescopic.
Re: Mini Whip.
If you want to experience on-line how the mini whip performs the webSDR at the University of Twente uses this aerial for VLF to just under 30 MHz coverage
http://websdr.ewi.utwente.nl:8901/
Re: Mini Whip.
Hi it was on Ebay UK although it actually came from Czech republic (not Poland) try this search 'MINI-WHIP - Kurzwellenaktivantenne ab 10kHz -~30MHz - BAUSATZ KIT LAST' sellers ebay name is 'karezo' hope this helps!
Superstar 360
Superstar 360
- Call Sign: M1ZXZ
Re: Mini Whip.
For £15 build it yourself, sounds ok.. If they prove to be too noisy then better off losing £15 than £99.
Gosman767 - Can you post some details, height location etc, your thoughts on how it be performed.
Would be interested to know how you got on with it..
For £15 just might be worthwhile. Thanks..
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: Mini Whip.
Dont forget to take some pictures of the construction and write us a nice little reviewM1ZXZ wrote:For £15 build it yourself, sounds ok.. If they prove to be too noisy then better off losing £15 than £99.
Re: Mini Whip.
The construction was simple, circuit diagrams on the sellers website, all components pretty easily sourced, (i've some spares if anyone else has a go). Packaged in a piece of water pipe (I think) that I had in shed. Not got it up yet, just bought 3 fibreglass poles from a fishing place at a £5 each that fit into each other, going to try it in garden about 5 metres from house but it will only be about 5 metrs high see how it works against my long wire, just an experiment really.
Superstar 360
Superstar 360
Re: Mini Whip.
Hi bought the Paordt Mini Active Whip almost 1 year it does an excellent job on hf but it needs to be mounted high and a few metres away from the house im comparing it to my 3 dwellbrook active loops..
Regards Lino..
Regards Lino..
