Best High End Portable.
Re: Best High End Portable.
Look out for a Lowe HF 150 superb takes batteries although it's a bit greedy has all the connectors and its a nice size for portable out and about .
- Test for Echo
- Call Sign: 2E0ECN
Coming in a bit late on this, and it's a rather expensive option, but the CommRadio CR1a is a very nice little radio. Although it will work with a whip on the back, it really needs a proper antenna. I've used an end fed wire with good results.
- Retrodog
- Call Sign: 26SW07
They are, I'm sure Ofcom have a few about the place. Rather a special piece of equipment at a rathr special price too.SecretShortwave wrote:these are pretty good http://www.rohde-schwarz.com/en/product ... 11926.html
- crusty
Ditto. Getting hard to find though, and the preselectors are like fairy dust.phil7ldx wrote:Look out for a Lowe HF 150 superb takes batteries although it's a bit greedy has all the connectors and its a nice size for portable out and about .
I can recommend the Tecsun PL660 for a budget shortwave. I've pulled in hams from the US and all over Europe with the supplied 5m wire. Also mid-atlantic aircraft and SW stations from all over.
- Clipper
I see Maplin have these for £99.99, not sure if they're the 2014 version with autostore etc. May wait until January to see if the price comes down.scanhermit wrote:I can recommend the Tecsun PL660 for a budget shortwave. I've pulled in hams from the US and all over Europe with the supplied 5m wire. Also mid-atlantic aircraft and SW stations from all over.
Check Ebay - I got mine for £82
- Clipper
- Sylad
Even cheaper Tecsun PL-660 & still in UK £34.99
http://www.ebay.co.uk/itm/TECSUN-PL-600 ... =undefined
Simon
Lincolnshire
26TM158 & 26DX617
INDEED YOU ARE POWERFUL !
Lincolnshire
26TM158 & 26DX617
Grundig/Eton G5 is very sensitive. It has SSB but lacks a dedicated USB/LSB feature. I've had no issues tuning SSB via the BFO.
- Admiral
- Call Sign: 26TM157
I have a high-end HF receiver that cost a fortune in the day, and it has a BFO rather than USB/LSB offsets, works for me.
- bc73
Sangean?
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
Nothing's ever easy!
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
- Admiral
No, it's an ancient JRC.
- scan125
- Call Sign: 26TM8080
If you have/get one and want to add a little computer control then checkout my HF150 Control Program and IF150 USB interface project.phil7ldx wrote:Look out for a Lowe HF 150 superb takes batteries although it's a bit greedy has all the connectors and its a nice size for portable out and about .
http://nick-bailey.co.uk/hf150/index.html
http://nick-bailey.co.uk/if150/index.html
