Kinloss Rescue
guitarman
Call Sign: swl18hl
Kinloss Rescue
Post by guitarman » 22 Dec 2013, 11:45
Hi all
Can someone tell me if Kinloss Rescue has been removed from Hf again as I cannot get the online radio to work
Thanks Guitarman
IC-R8500
Uniden UBC3500XLT
DX-394
SE HF360 FIBRE GLASS VERTICAL
End fed wire
AR-30 white stick
At-2000 Atu
thelad
Re: Kinloss Rescue
Post by thelad » 22 Dec 2013, 13:54
I thought they stopped the uplink a long time ago. Do you have the web link?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
guitarman
Call Sign: swl18hl
Re: Kinloss Rescue
Post by guitarman » 22 Dec 2013, 15:53
IC-R8500
Uniden UBC3500XLT
DX-394
End fed wire
AR-30 white stick
At-2000 Atu
Shetlander
Re: Kinloss Rescue
Post by Shetlander » 24 Dec 2013, 20:48
You will find a current online stream here:
http://www.broadcastify.com/listen/feed/15811
Happy Listening!
guitarman
Call Sign: swl18hl
Re: Kinloss Rescue
Post by guitarman » 25 Dec 2013, 10:05
Thank you Shetlander
IC-R8500
Uniden UBC3500XLT
DX-394
End fed wire
AR-30 white stick
At-2000 Atu
grafter
Re: Kinloss Rescue
Post by grafter » 25 Dec 2013, 13:42
[quote="Shetlander"]You will find a current online stream here:
Happy Listening![/quote ]How much delay is there on this stream, been listening for about 20 minutes and nothing I've heard matches what I'm receiving direct on 5680kHz?
Shetlander
Re: Kinloss Rescue
Post by Shetlander » 25 Dec 2013, 23:56
grafter wrote:
Shetlander wrote:You will find a current online stream here:
I am not to sure about the delay. Certainly everything I have heard matches with real time events...?
Shetlander
Re: Kinloss Rescue
Post by Shetlander » 28 Feb 2014, 21:40
I think this feed is now offline.
Does anyone else know of a Kinloss Rescue 5680 feed??
26FB096
Call Sign: 26FB096
Re: Kinloss Rescue
Post by 26FB096 » 28 Feb 2014, 21:42
They did shift frequency the other day because of jamming/abuse coming from our friends in Eastern Europe..
Minus1
Re: Kinloss Rescue
Post by Minus1 » 28 Feb 2014, 22:12
Shetlander wrote:I think this feed is now offline.
You can use this online SDR to get any HF signal (although the RX is in Enschede in the Netherlands)
http://websdr.ewi.utwente.nl:8901
