VECTRONICS AT-100 INDOOR ACTIVE ANTENNA ?
- WARLOCK
- Call Sign: 26TM134
Anyone use or have used a vectronics at-100 indoor antenna can you please tell me if this antenna is any good for me ,i live in a ground floor flat with no garden so cannot put a long wire out , if this is no good is there another antenna you could suguest that i could use . warlock1946
- marcusabacus
Re: VECTRONICS AT-100 INDOOR ACTIVE ANTENNA ?
If you cant hear a signal then an active antenna wont help.....
Try running a wire around the room at ceiling level.... or get a wellbrook loop , expensive but worth it.
Waak Waak
Signal R-537S
Baofeng UV-5R
Baofeng GT-3
Yaesu VR160
Uniden Bearcat BCT15X
Tecsun PL365
Sony ICF-5500M
Commradio CR1A
Whistler TRX-2
Uniden UBC3500XLT
Commtel COM207
Nasa HF3
Kenwood R600
Yaesu FRG7
Signal R-537S
Baofeng UV-5R
Baofeng GT-3
Yaesu VR160
Tecsun PL365
Sony ICF-5500M
Commradio CR1A
Whistler TRX-2
Uniden UBC3500XLT
Commtel COM207
Nasa HF3
Kenwood R600
Yaesu FRG7
