64 khz
64 khz
Does anybody know if there are any voice transmission's down here. I'm picking up something that sounds like a broadcast radio station with music and possibly French language. I suppose its probably just spurious or even a harmonic but just wanted to check.
Re: 64 khz
I would not have thought there were any voice stations down there
- Andy
Re: 64 khz
It must be a spurious response in your rx. See if you can identify what station it is (it's probably in the LW somewhere) and then you can work out what's happening.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- Minus1
Re: 64 khz
There is a good signal on 64 kHz on the Enschede SDR, but it sounds like one of the various navy submarine transmissions.
http://websdr.ewi.utwente.nl:8901
It definitely won't be voice right down there.
At least the Enschede SDR will show you what you should be receiving on 64 kHz.
