Kinloss very weak through daytime.
mikecharlie
Post by mikecharlie » 06 Jul 2013, 23:27
Is any one else noticed this, that Kinloss seems to be very weak through out the day time.....Kinloss was barely readable the last few days in the afternoon, picking up later on, but still not as strong as it is usually.......
transmitter low power, or transmitter site down.......?
tries Shannon 5.505, and that was banging in at the same times........so its not a radio, antenna problem here.
Radio, wall of sound, coming up from my tower...
Radio, wall of sound, 24 hours of power...........!!!
crusty
Re: Kinloss very weak through daytime.
Post by crusty » 06 Jul 2013, 23:45
Can't verify MC, damaged coax. Nice to see you posting, hope you're well.
mr_h4ck3rm4n
Call Sign: MM6SGZ
Post by mr_h4ck3rm4n » 07 Jul 2013, 10:26
Kinloss have a few TX sites in the UK, what site they use depends on the area they are 'working' in ....
listening to Kinloss talk to S125 (weak).... then Navy193 and Kinloss weaker but both sides audible,
R177 both sides louder.
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
mikecharlie
Post by mikecharlie » 07 Jul 2013, 20:18
crusty wrote:Can't verify MC, damaged coax. Nice to see you posting, hope you're well.
Hey,. Chris...hope you are well also.!
I have drifted away from the hours of HF listening the last while, tend to end up listening to 5680 in the background, and haven't done much HF faxing lately.
you quiet on the radio listening as well crusty?
Gemini4
Post by Gemini4 » 08 Jul 2013, 11:57
kinloss is very quiet even when its broadcasting just lately...it use to be nice load and readable..but its awful now.i assume your right and it is low power.
crusty
Post by crusty » 08 Jul 2013, 16:21
Yes I've drifted also. Made the mistake of getting into building test gear, which has branched me away from using radios ironically. :oops: Bench full of started projects, need have a clear out and get back to it.
Gemini4 wrote:kinloss is very quiet even when its broadcasting just lately...it use to be nice load and readable..but its awful now.i assume your right and it is low power.
Could be. Might also be connected to the restructuring they underwent recently. Who knows, could also be as mr_h4ck3rm4n suggests. Their transmissions have been variable on many occasions in the past.
mikecharlie
Post by mikecharlie » 08 Jul 2013, 20:49
I am wondering if it is just a temporary weakening of signal. it picks up quite a bit later on, but only due to propagation.
5.505 and 5.450 volmets absolutely banging in. while 5680 is very weak, and variable. but not much more that 3 S points.
and as fas as I know, Kinloss only have about 3 tx/rx sites over country, each up to 10kW......I do not think that they selectively use some sites more than other, such as the nation wide coverage the HF produces.......
I think its a temporary lowering of power for maintenance, or its a fault worth one of the Tx/rx sites ,and it wouldn't be the first time believe me.......
radio_ryan
Post by radio_ryan » 11 Jul 2013, 09:52
I have noted to over the past few days kinloss is very quiet lately when its broad casting.
Put it down to the weather, but I can only just hear it with the pre amp on. nice to know it not just me having the problems.
crusty
Post by crusty » 11 Jul 2013, 10:33
There's a geomagnetic storm underway at the moment. Not good for HF reception, VHF is having a ball though.
marcusabacus
Post by marcusabacus » 11 Jul 2013, 15:22
Kinloss is fine during the day here.... 7-8 signal with no interference.
Waak Waak
Signal R-537S
Baofeng UV-5R
Baofeng GT-3
Yaesu VR160
Uniden Bearcat BCT15X
Tecsun PL365
Sony ICF-5500M
Commradio CR1A
Whistler TRX-2
Uniden UBC3500XLT
Commtel COM207
Nasa HF3
Kenwood R600
Yaesu FRG7
mikecharlie
Post by mikecharlie » 11 Jul 2013, 19:17
interesting you say that crusty!, that is what I had thought as well.
and I remember that about year ago I made a post on here about Kinloss actually broadcast a warning to the helos that a forecast solar flare was forecast to severely interfere with the Hf communication s that day.
yesterday It sounded a lot louder at the same time, but today it has been weak and variable again, even one or two of the helicopters were louder on some occasions..it is strange.
5505 and 5450 were thundering though......something funny going on.
mikecharlie
Post by mikecharlie » 12 Aug 2013, 20:12
now there is interference from a stanag signal that is degrading the channel......seems to be the last week, seems to start transmitting at about 18.00 Hrs........why the hell do they not change to some other 5 meg channel.......5699 was / is a military use channel....etc
and still the channel at some times of the day, the signal is woefully weak, and even some of the mobiles have reported that they are 'barely readable', and 'extremely quiet' and 'very weak'.....
Digital
Post by Digital » 12 Aug 2013, 22:40
They seem to be around 5698 KHz this evening.
That STANAG signal really is right on top of 5680 KHz.
