Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
I've been trying to get Kyodo news for a while.
It seems to be a bit hit and miss, often fading completely.
This is the most recent and fairly readable copy of NX warnings and Sumo results, received this morning on 16971 at 1130-1145.
Kyodo Ive found can be pretty strong on 17430, in afternoons, but this is usually in the summer months.
Also can be good on 12745.......the problem is that because they are tx'ing in rpm60, it takes sooo long for it to tx compared to a normal 120rpm station ,that its more subject to fading etc........
You should try New Orleans on 17145 in the afternoons around lunchtime, its potentially very good at times. The Ir satelite Img at 14.00 GMT, is a good catch.
Also try taipei on 18560 at 13.20, as they tx an interesting IR image also, but this station is more difficult.
Radio, wall of sound, coming up from my tower...
Radio, wall of sound, 24 hours of power...........!!!
Now thats not a bad decode!
Heres mine on 12750 from Sunday mid afternoon (1503) transmission.
Sony ICF-SW7600GR, G5RV jr slung roughly in the garden about 10 ft above ground level.
Crap loads of noise due to position of antenna and feed probably being not upto much.
Not bad though for a mid afternoon decode.
Notice the low pressure system and swirl to the right middle of the picture, and the cloud thats above it. I do believe thats whats being causing our particularly crappy weather the past few days!
Back on HF due to change of location and more filters on the baby monitor!
HEADS UP inuvik heard on 8456khz at 2300 very weak maybe one to look out for
sydney vco canada on 4414.2 khz sig 7 at 23:27 chart in french, some noise on chart but a very easy copy.
missed beggining of tx so this could be final chart i think they use to qrt after 3 charts at about 2345 but
things may have changed, it's been a while since i did any wefax
kyodo making the trip on8465.7 at 23:51 sig 2 a noisy chart
palstar r30a rx
1026 antenna phase filter
784b dsp
wellbrook loop + 60ft long wire
EDIT Sydney qrt at 23:45
hey John....how-ya doing?. I think you were still SS, last time we spoke.
Yeah Sydney on 4416 can be decent at nights. A lot of those more obscure stations come back on from July to November dont they. Resolute on 7710 etc.......
Chile may be good as well on 17145 in the summer time nights hopefully........
i think I heard Australia the other day on 15615, then. It becomes splattered with a broadcast station after 13.00 I think.
There Is a strong stang signal been polluting Wiluna on 10555 recently as well.
I havent been doing much fax recently.........Will get back into it eventually.
PS What time did Sydney start.......Was if sometime after 23.00 John..?
heyup fella how yer doing i was in edit mode when you posted so info is now in my original post, they used to start at 2300 i think, it's been a while but was talking to a friend who is going to give wefax ago so thought i would have a tune around, hearing a few but signals are little bit down listening to kyodo on 8mhz has i type, it's like old times nice to see you still posting here im gunna try and get in front of the radio more
sydney canada on 4414.2khz making the trip
listened for sydney tonight (thurs) showed up at 22:00 till 2230 nothing at 2300
murmansk very strong on 8mhz at 1900 the chart shows loads of scribbles and is meaningless but they still broadcast it and have for a long time now, beats me
12.4781 seems to be a freq that is sometime used in error i cannot remeber if it is boston or new orleans has i aint got the log handy, i seem to remember posting something simular a while back
regards
I suspect that you have used the wrong IOC though, it is very elongated image.
All fax stations now use an IOC of 576, so make sure its on 576.
I suspect you mistakenly used 267 or 288.....
Also make sure that you set it to 120 LPM as well as IOC 576.
If you are receiving Kyodo however, make sure its LPM 60, and IOC 576.
I have been absent from fax for a while now.........I wonder If Kyodo is making the trip now on 17430 in the afternoons.?
