Ground Terminal
Shambles
Call Sign: M6CEF
Ground Terminal
Post by Shambles » 13 Nov 2017, 21:28
Anyone advise on this for me, during a discussion at the club it was brought up about putting a ground terminal for the radio, Can anyone tell me if it's necessary to do this :problem:
Tigersaw
Call Sign: G6RRL
Re: Ground Terminal
Post by Tigersaw » 13 Nov 2017, 22:03
No, its a bad idea spouted by know alls. If its any run at all it will become a counterpoise and mess your antenna up, you may get hums on TX and if your PSU is a switch mode with the -ve and earth connected (some are) you will even compromise your house protection.
Only place and time to earth your radio is if your out in the field on a table with the grass a foot below.
Earthing aerials across baluns or on external ATU's - yes, but thats different.
Shambles
Call Sign: M6CEF
Re: Ground Terminal
Post by Shambles » 13 Nov 2017, 22:09
Super reply thanks
