Cardiff Airport UHF
welshevo
Call Sign: 163TM995
Cardiff Airport UHF
Post by welshevo » 03 Jun 2016, 10:33
morning all, a bit bizarre but have had Cardiff airport Radar, Tower, and Ground all on the 1 UHF frequency, 455.7000
but also this same freq also picks up Bristol airports Tower...
Mikel
Re: Cardiff Airport UHF
Post by Mikel » 03 Jun 2016, 13:13
Isnt this the service that relays air movements to airport ground staff who will be listening on their UHF handies? I suppose the fact that the 2 airports are almost 30 miles apart means that there is not much chance of interfering with each other - most likely using different ctcss or dcs as well (well down in the noise here).
If you look at the profiler tool output (Cardiff airport on left and Bristol Airport on right) Bristol has a fair bit of elevation in its favour mind you:
Profile produced with http://www.heywhatsthat.com/profiler.html
thelad
Post by thelad » 03 Jun 2016, 17:51
Yes Uhf relay for ground staff.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
bigbloke
Post by bigbloke » 04 Jun 2016, 20:04
listen around 455 / 456 amd you will also find a MPT1327 trunk system for ground crews
Regards
BB
wheelbarrow
Post by wheelbarrow » 05 Jun 2016, 13:37
That'll be for GMC (Ground movements) - pushback tugs will have UHF mobiles like GM360. Some airports only use VHF AM for ground movements and some transpond / cross patch onto UHF as well.
The MPT system is for the airport authority and for ground handling companies like Menzies, Aviator, etc who will use the trunk radios to despatch flights, refuel, deal with passenger stuff etc.
Metradio
Call Sign: G7HID
Post by Metradio » 06 Jun 2016, 11:41
Some of the Heathrow and Gatwick Ground movements are on the same frequencies with different CTCSS tones
Mike
Bruin
Post by Bruin » 29 Jun 2016, 12:42
That's an interesting graphic and explains exactly why from Cardiff west I can hear everything at Bristol including fire trucks, Ops vehicles and taxiing aircraft but I hear nothing from Cardiff Rhoose.
