Hi all,
Anyone know of a good source for one of the above.
I've got a bit hooked on Virtual Radar with my RTL stick and would like to take it out in the car so thought a small magmount would be ideal.
Are there any that are made specifically for this use?
Ta
Mark...
ADS-B 1090MHz mag mount antenna
Uniden UBCD3600XLT| Uniden UBC780 XLT | Commtel COM215 | Realistic Pro-35 | Realtek RTL820 SDR x4 | SDR Play RSP2 | PiAware/Flightaware ADS-B Receiver | Yaesu FT-891 | Yaesu FT-817ND | Wouxun KG-UV8D | Tytera MD-380 | Anytone AT-D868UV
Re: ADS-B 1090MHz mag mount antenna
Specialist in Aviation.
- radioenthusiast2011
Simple solution for you...........
buy this taxi antenna from maplins.............. http://www.maplin.co.uk/p/14-wave-vhf-t ... ount-n23ac
and cut it for 1090MHz.(change connectors or use adaptor)
should work a treat and doesnt cost much!
