rogerbeep wrote:If you have a blocked tail number still you must send ADS-B transimissions, but it shall not be "relayed" outside the ATC organisation.
I agree with you that operators can request that their flights are not shown on these websites. But the above is just wrong. Anybody with equipment can pick up ADS-B transmissions, they don't need to be "Relayed outside the ATC Organisation".
rogerbeep wrote:
This is also incorrect. I referred to airline companies and their ground organizations. As you most probably know ATC is owned by the government in each country and they (obviously) have more flight info available on their desks. "ATC owned" data is not available for private companies.
A friend of mine is working at the OCC (Operation Control Center) in one of Europe's leading airline companies. They use public information (as found in Flightradar24) to plan everything related to a flight. And believe me, he can't see VIP flights either.
First off, ATC in the UK is not owned by the government. The government have a share, along with some major airlines and other companies.
Secondly, I seriously doubt that any airlines would use information from amateurs sharing ADS-B data on the internet to organise their operations. If you can prove that they do then I'll be surprised.
Also, how did airlines manage before FlightRadar24? Or before ADS-B? Or before Mode-S? Or before Mode-C? Or before Mode-A? Or before Radar?
rogerbeep wrote:
Where can the OCC's find running information about updated ETA if they don't want do bother the flight deck officers with a lot of unneccesary ACARS-transmissions ?
In the UK at least it works like this....
We have a system called NAS (National Airspace System) that is basically a database of all UK flights showing, Reg, Callsign, Operator, Route, Squawk, EOBT, ETA, ATD, ATA etc. This system is kept up to date using various sources including feeds from the CFMU (Central Flow Management Unit) in Brussels and feeds directly from the controllers electronic strip displays. There is also a system in use at the airports called Chroma which uses a feed from the radar to "Fine Tune" the ETA and then feed it back to NAS (Chroma is where the airport public display systems get their information from). The information from NAS is provided to the airline operators as part of their route charges.
For private operators or for airlines wanting more information (Like flight tracking via ADS-B) they will use a third party website like Flight Aware (which you linked earlier), to gain access to the information. Flight Aware is in no way like FlightRadar24 however. For a start Flight Aware does not rely on amateur operators to provide data, they have their own ADS-B receiver stations. The data provided by Flight Aware is still only a nicety though, airlines and other companies in no way "rely" on it.
If ADS-B were to disappear tomorrow, believe me, air transport operations would continue on as if nothing had happened.
