Air to Air
Volvo
Air to Air
Post by Volvo »
Hi
Does anyone know if the helis working Anglia radar have an air to air frequency?
Pete
PSR295 SBS1er Auroa ssx Bct15x
pete_uk
Re: Air to Air
Post by pete_uk »
123.45 is (as far as I know) a unofficial air to air frequency.
Minus1
Re: Air to Air
Post by Minus1 »
123.45 is actually defined by the ICAO as an air to air frequency.
"4.1.3.2.1    An air-to-air VHF communications channel on the frequency of 123.45 MHz shall be designated to enable aircraft engaged in flights over remote and oceanic areas out of range of VHF ground stations to exchange necessary operational information and to facilitate the resolution of operational problems."
No doubt bureaucrats will have an argument about what constitutes a "remote" area.
Since Google has become obstructive about allowing you to copy links, you'll have to search for it yourself. Try ICAO and 123.45 look for a DOC under icao.int
118.0 is also used now and again as an A2A.
What are these helicopters you refer to?
Glamdring
Re: Air to Air
Post by Glamdring »
Minus1 wrote:What are these helicopters you refer to?
Helis out of Humberside, Norwich and North Denes carrying equipment and personnel to the gas rigs in the southern North Sea. They all work Anglia Radar which is based at NATS Aberdeen.
Minus1
Re: Air to Air
Post by Minus1 »
Various web sites give a dozen or so freqs used by various oil rigs.
Some seem to be shared by multiple rigs in the same area, so might also be used for A2A.
If the rig is a long way from land, any low level freq might be used.
You might try these for starters:
122.02500
122.32500
122.37500
122.87500
123.62500
123.65000
125.17500
129.77500
129.95000
130.87500
133.57500
I can't confirm any of these personally, so no idea how accurate or up to date this list is.
Glamdring
Re: Air to Air
Post by Glamdring »
Most of the rig frequencies are shared between neighbouring rigs in the same field. The rig frequency is used to give the helis traffic information & rig status prior to landing. The rest of the time they are talking to Anglia Radar.
A map of Anglia Radar's area is available Here
The rig frequencies and also the NDB frequencies for the rigs are detailed towards the end of This Document
Any other questions about offshore ops give me a shout (I've worked almost all the UK offshore sectors including Anglia Radar :) )
dcwuk
Re: Air to Air
Post by dcwuk »
Having trouble accessing the links you provide
Forbidden
You don't have permission to access /pamslight/pdf/4e415453/EG/C/EN/Charts/ENR/EG_ENR_6_1_15_3_en on this server.
and
403 forbidden requires login
Can you help as I am interested in this info?
regards
dcw :)
Glamdring
Re: Air to Air
Post by Glamdring »
mr_h4ck3rm4n
Call Sign: MM6SGZ
Re: Air to Air
Post by mr_h4ck3rm4n »
Nice doc, cheers!!
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
Volvo
Re: Air to Air
Post by Volvo »
Thanks for that information chaps, interesting docs. Heli traffic in and out of HBR seems on the up.
