GATWICK UHF Help
Beefi
GATWICK UHF Help
Post by Beefi » 12 Oct 2013, 15:44
Hi Guys
My research continues and now I think I need some help from someone 'In the business"
With regards to my previous post and trying to find the UHF rebroadcast frequencies of ATC for major airports, I have drawn a blank for Gatwick - kind of local to me.
I understood there was a rebroadcast of the tower and ground frequencies at most airports, indeed information received confirms this but Gatwick is a mystery. According to Ofcom WTR only one frequency is licensed by NATS and that rebroadcasts the ground ATC frequency, and thats it. Looking at Manchester, NATS has licensed the frequencies that I have been supplied with on my other post. So it would appear Gatwick only rebroadcasts the ground frequency and not the tower. Is this so? If it is true why no tower rebroadcast?
I am sure someone will supply the answer very soon
Thanks for your help
Beefi
Minus1
Re: GATWICK UHF Help
Post by Minus1 » 12 Oct 2013, 16:59
Birmingham only rebroadcasts the Ground freq too.
Ground vehicles have no need to talk to airbourne aircraft, but perhaps at some airfields, the tower freq has control of runway crossings for ground vehicles.
Beefi
Post by Beefi » 13 Oct 2013, 09:07
Good point, I have heard shuttle buses and runway inspectors on the channel so perhaps you are right, there is no need to broadcast the tower frequency, everything is done on the ground channel. According to the NATS details it is a duplex frequency so makes sense.
Thanks for your input
Beefi
thelad
Post by thelad » 13 Oct 2013, 14:50
At LBA the tower uhf is used for ground vehicles listening in for runway/ground movements and also for the crash teams. the fire appliances never use the airband frep that is allocated.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
thelad
Post by thelad » 13 Oct 2013, 15:21
found some UHF for Gatwick.
TX: 453.925 MHz
RX: 460.425 MHz
TX: 453.4375 MHz
RX: 459.9375 MHz
TX: 442.575 MHz
RX: 428.075 MHz
TX: 446.375 MHz
RX: 446.375 MHz
TX: 442.850 MHz
RX: 428.350 MHz
TX: 456.600 MHz
RX: 462.100 MHz
TX: 453.875 MHz
RX: 460.375 MHz
TX: 441.075 MHz
RX: 426.575 MHz
TX: 440.350 MHz
RX: 425.850 MHz
TX: 441.250 MHz
RX: 426.750 MHz
TX: 441.050 MHz
RX: 426.550 MHz
TX: 441.125 MHz
RX: 426.625 MHz
TX: 441.550 MHz
RX: 427.050 MHz
TX: 441.800 MHz
RX: 427.300 MHz
TX: 441.700 MHz
RX: 427.200 MHz
TX: 453.1125 MHz
RX: 459.6125 MHz
TX: 453.300 MHz
RX: 453.300 MHz
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
