Antenna
tesco1
Antenna
Post by tesco1 » 29 May 2013, 15:46
Anyone know what the quality of a Sharmans Multi Band Antenna is like in comparison to a Discone. :|
rocket
Call Sign: M0ROC
Re: Antenna
Post by rocket » 29 May 2013, 18:28
Which one - SE1500 (Superscan?)
73 de Mark
M0ROC, 26HB896, 26TM896
M0LGC (Letchworth Garden City Amateur Radio Society)
Flightradar24 live feed: T-EGGW38 via AirNav RadarBox 3D
tesco1
Re: Antenna
Post by tesco1 » 29 May 2013, 18:33
Sharmans wideband Multi-Scan base scanner antenna.
rocket
Call Sign: M0ROC
Re: Antenna
Post by rocket » 29 May 2013, 18:45
This is AKA the SE1500 (called different things by different suppliers)
What is your main area of listening interest?
73 de Mark
tesco1
Re: Antenna
Post by tesco1 » 29 May 2013, 19:32
Wideband, Air, CB, Taxis, etc
rocket
Call Sign: M0ROC
Re: Antenna
Post by rocket » 30 May 2013, 07:43
Then the SE1500 then I'd say. The base double discone is quite good too but is obtrusive and prone to wind damage.
If you want a really good airband antenna then go for a Diamond D777
73 de Mark
tesco1
Re: Antenna
Post by tesco1 » 30 May 2013, 09:43
Thanks rocket, by the way have you heard of a Eurostick DX 25-2000Hz Base scanner Antenna, any reports? will keep the SE1500 in mind, also need decent cable for 25 metres, somebody mentioned Westlfex 103.
rocket
Call Sign: M0ROC
Re: Antenna
Post by rocket » 30 May 2013, 13:09
Eurostick is OK, but not as good as the SE1500 performance wise and construction quality isn't as good either.
Westflex is perhaps a bit overkill, condider RG8X Mini 8 as it should be OK for that length (also cheaper)
73 de Mark
