Contrails...or not?
- kr0ne
Re: Contrails...or not?
Did further research show Glamdring's suggested explanation in post 2 to be incorrect?
I am not a wearer of the tin foil hat BUT
I have alway watched the skies and when i was younger contrails did what they should do as they are water vapour, what they did was disapear shortly after but some of the ones of today dont and can completly block the sky and sun. i have watched it
- grahamwilman01
- Call Sign: 2E0CSU
the tinfoil ain't working anymoreSadToes wrote:I am not a wearer of the tin foil hat BUT
- grahamwilman01
- Call Sign: 2E0CSU
it only happens above 27000 feet doing my own research into this daft conspiracy theory it depends on temperature and humidity conditions at altitude that form the contrailsbigbassman wrote:Exactly.Well then,why doesn't it happen all the time?(which was my original question).How come sometimes contrails form,and sometimes not?Surely it can't get too warm up theregrahamwilman01 wrote:Let me put it in easy terms for simpletons to understand, you know when you start your car on a very cold morning and you get the hot gas from the engine hitting the cold air you get what looks like steam, it is known as condensation that is exactly what happens at 30000 ft where temperatures can get as low as minus twenty seven it is the hot exhaust from the aircraft hitting the cold air not some evil government project to turns us into retarded mutants conspiracy theories are like sh1tholes everyone has one
- kr0ne
Maybe it would help? Would keep the sun off your head at least...SadToes wrote:I am not a wearer of the tin foil hat BUT
Sure....... because the government would never lie to us would they?
Jeez... try thinkining out of the box sometimes
Personally I'd just try thinking
But seriously, no.
But seriously, no.
Steve. IC-R8500, IC-706MKIIG, TM-V71E, BCT15X, VX-8DE, IC-R20. Diamond X200N & X30, Wellbrook ALA1530S+, G5RV.
- grahamwilman01
- Call Sign: 2E0CSU
SadToes wrote:Sure....... because the government would never lie to us would they?
booooooooooored
yes and Father Christmas and the tooth fairy exist
It made sense to me.Unfortunately I think I used the wrong wording in my heading.When I wrote "Contrails..or not" I didn't mean 'are they contrails or are they not?' Unfortunately the content has wandered WAY off course. Honestly,I just wanted to know why some days there are lots of trails (see what I did there?) and some days there are none at all.kr0ne wrote:Did further research show Glamdring's suggested explanation in post 2 to be incorrect?
2 X PRO 2006 1 X DX-394 1 X GRE PSR 282 1 X UBC780XLT with ProScan 1 X Pro43 1 X Yaesu FRG 100 Uniden 125 XLT LCL 2740.
- Banned
It's to do with the 'dewpoint'. The relationship between moisture and temperature. Don't forget that any moisture sucked into the front of the engine doesn't disppear - it just gets blown out of the back much hotter.
'Dewpoint' is the point below where moisture ceases to exist as an invisible 'gas', and condenses out into water droplets. So - at sea level - wet air on a hot day is 'muggy' but wet air on a cold day is fog.
As an aircraft climbs, it will reach an altitude where the air is cool enough to fall below the dewpoint. This is why if you see an aircraft climbing it will start to make a contrail. This altitude varies according to the air temperature and its moisture content. In hot dry weather you will see aircraft flying very high with either no contrail, or a very short-lived one, but in cold weather the dewpoint altitude will be much lower, so you get the opposite.
For the same reason, it's better to photograph steam engines in freezing weather than on hot summer days.
- kr0ne
What does this mean, exactly? I hear it a lot at work but nobody who says it seems to have any idea...SadToes wrote:try thinkining out of the box sometimes
- kr0ne
Yeah, I know you weren't asking loony tunes questions...bigbassman wrote:It made sense to me.Unfortunately I think I used the wrong wording in my heading.When I wrote "Contrails..or not" I didn't mean 'are they contrails or are they not?' Unfortunately the content has wandered WAY off course. Honestly,I just wanted to know why some days there are lots of trails (see what I did there?) and some days there are none at all.
Glamdring suggested an explanation as to why they do not always appear in post 2 though and grahamwilman01 says that he has now also read a little about the subject and came to a similar conclusion.
- kr0ne
Excellent reply!ChrisCSL wrote:It's to do with the 'dewpoint'. The relationship between moisture and temperature. Don't forget that any moisture sucked into the front of the engine doesn't disppear - it just gets blown out of the back much hotter.
- Banned
Thankee.
Also, don't forget that at high altitude, the water droplets will in fact be ice crystals, which makes for a very impressive contrail.
I live under a transatlantic air lane, and some mornings in mid-winter you can see aircraft flying among several earlier contrails. It's beautiful at dawn.
During the war, one of the jobs of the tail-gunner on bombers was to warn the pilot when he was generating a contrail. The German fighters might not have been able to spot a black Lancaster, but all he had to do was follow a moonlit contrail and ..... endgame.
That about does it for me Chris.Explained in a nutshell.I had wondered about the short trails as well.Thanx a lot.ChrisCSL wrote:It's to do with the 'dewpoint'. The relationship between moisture and temperature. Don't forget that any moisture sucked into the front of the engine doesn't disppear - it just gets blown out of the back much hotter.
