AIRNAV RADARBOX ON A PLANE
As the title says, I'm flying to Abu Dhabi in a few weeks on Etihad. I've flown with them a few times and they provide an in seat power outlet for laptops, phones ect....
I'm wondering if I should "risk" taking my airnav radar box with me, I've upgraded with my airmiles so I'm flying business class, meaning I'll have my own, personal, private seat, I've tried an FM/AM radio on the same flight route and I had BBC radio up until northern Germany. I need advice
Should I take my airnav with me and use it? I don't want people to think "terrorist". A laptop, with a wire attached to a black box and an antenna doesn't look good...hmmm what to do
Re: AIRNAV RADARBOX ON A PLANE
I personally wouldn't want to risk the un-due attention it could bring lolkiwi272 wrote:As the title says, I'm flying to Abu Dhabi in a few weeks on Etihad. I've flown with them a few times and they provide an in seat power outlet for laptops, phones ect....
You could ring the airline and ask them if you can use it and if they say yes, ask for confirmation in writing or by email so you can print it out to show the crew
failing that (or if the airline say no), and your sure you`ll get past security with it, ask to speak to the captain when you board, show him the airnav and maybe demonstrate it on the ground for him, show him that it is receive only and what the box does and see if he says yes, after all, its his flight and he has over all responsibility for the passengers and crew, you never know, the captain might even be an airnav owner lol
26TM234
- liamcarbin
What about getting a dongle which can be used as an ads-b receiver instead?
https://www.cosycave.co.uk/category.php?id_category=61
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
Moonraker Skyscan Mobile Antenna
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
- Glamdring
Interesting. Does that work well? I'm guessing some kind of software is required to change the functionality?liamcarbin wrote:What about getting a dongle which can be used as an ads-b receiver instead?
- liamcarbin
Works very well. I have one. You can set it up to be used with planeplotter or you can use software called GLobe S. http://rtl1090.jetvision.de/Glamdring wrote:Interesting. Does that work well? I'm guessing some kind of software is required to change the functionality?liamcarbin wrote:What about getting a dongle which can be used as an ads-b receiver instead?
Many users of the dongle also have Airnav/Kinetic boxes and they say the dongle performs just as good and in some cases better. The antenna that it comes with however is good but I upgraded mine to an antenna designed for ADSB and I am now recieving much more aircraft.
Very helpful website here, which has videos of how to set the dongle up etc and links in the videos to download all the neccessary software etc.
nicstorey.co.uk/planeplotter/Getting Started
For the money I paid for it I am more than happy
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
- liamcarbin
Here are a few images so you can see what it's like
Dongle using Planeplotter
Dongle using Globe-S RTL1090 edition
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
- Glamdring
Nice. Would this also work with a PCI DVB TV card?
As far as I know it only works with dongles containing a certain chipsetGlamdring wrote:Nice. Would this also work with a PCI DVB TV card?
26TM234
- Glamdring
Just ordered a dongle for a tenner. Beats the 400+ quid for the Kinetics box.
- liamcarbin
I'm afraid not, it only works with a specific chip from realtek.Glamdring wrote:Nice. Would this also work with a PCI DVB TV card?
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
- liamcarbin
Certainly does, £10 for an ADSB receiver, you cant go wrong really.Glamdring wrote:Just ordered a dongle for a tenner. Beats the 400+ quid for the Kinetics box.
Word of warning, do not install the drivers from the disk that is provided.
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
I have never tried on of the tv dongle type things but I use the MicroAdsb ..... http://www.microadsb.com/
It`s more expensive then the tv dongles but still a damn site cheaper than the Kinetic/Airnav offerings.
I am thinking as a bit of an experiment trying to see if my Funcube Pro+ would do it as well. Would be interesting to see the reception difference between the two.
- nerdsville
My understanding is it won't work since it doesn't have the necessary bandwidth to allow decoding of ADSB signal, the DVB-T dongles can sample greater than the 192KHz possible with the FCDP+neil-c wrote:I am thinking as a bit of an experiment trying to see if my Funcube Pro+ would do it as well. Would be interesting to see the reception difference between the two.
- kr0ne
You want one with the RTL2832 chipset and the R820t tuner chip...
I've bought quite a few from here now and so far no duds:
http://www.ebay.co.uk/itm/170942168690? ... 1497.l2649
The main thing that they are lacking is front end filtering. If you can add this yourself then you are really laughing but you can get fairly decent results barefoot as well.
There are a few threads about these on here but check out this site for starters:
http://sdr.osmocom.org/trac/wiki/rtl-sdr
I have one connected to a Raspberry Pi SBC which runs a Linux based OS and some software that uses the dongle and serves up the I/Q data over TCP/IP via the rPi's Ethernet connection.
This means that you can have the dongle located at the antenna and just run a single piece of Cat5 up to it to provide power and data. You then just point SDR#, or whatever, at the IP address you have given to the rPi and away you go - no cable losses!
I have also written a shell script that reads the incoming frequency changes being sent to the dongle and uses this to switch on and off different LEDs attached to the rPi, depending on the frequency set. My plan is to build a bunch of filters and switch them in and out using PIN diodes in place of the LEDs. A simple PHP page can also also be used to make manual alterations to to the filter selections, or even switch in a LNA.
I had my first child a couple od days before Christmas though, well... the missus did... so all my projects are kind of on hold at the moment. The little bugler is asleep on my knee as I type...
- bingybongy
Be interested in seeing your script, if you dont mind sharing?
Bingy bongy dingy dangy ...
