This frequency activated my close call on my BCT15X, it's very active. Googled it like I normally do, but can't find what/where it is from?
Can anyone advise me please?
130.9333
- Minus1
Re: 130.9333
You can find all this stuff here http://www.nats.co.uk/do-it-online/ais/
Although it is the usual nightmare to navigate (ironic really).
Go to "UK Aeronautical Information Publication (AIP)."
Then "Enroute Information - ENR Index"
Then "ENR 2.1"
Bookmark that or download the PDF, cos you'll want it again…
You'll see 130.925 is shown for various sectors. (It's complicated)
The relevant bit for you will be EGBB inbound/outbound flights.
It is 130.925, not 130.93333, (not that the BCT15X will notice with a strong signal).
It is a 25kHz wide channel not an 8.33 one.
To make life more interesting, it's a channel that uses multiple sites, some of which are offset by 7.5 kHz to reduce cross interference.
The site at Daventry or Clee Hill (I haven't figured out which yet) is on 130.9325, but you need a scanner with a centre meter to deduce that, or do a lot of fiddling with the band scope and 5k and 7.5k steps near to the transmitter.
You're lucky to get a close call on that, I only get them occasionally here (about 10 miles from EGBB)
Then "ENR 2.1"
Re: 130.9333
Cheers for the info, I'll take a look tomorrow.Minus1 wrote:You can find all this stuff here http://www.nats.co.uk/do-it-online/ais/
Then "ENR 2.1"
I've only had the close call activate on this frequency tonight, but I'm getting a full on signal, and I'm using a "sheeeeeeeite" antenna as have been told on here!
