Now joy with that, but I noticed RTL1090 was giving me a different port at the bottom of the window compared to the 'Config' menu, so I put that into PP and it works!
Its quite good when you get into it. 2 RAF tankers heading southwest over Cirencester way, had a Tornado over wales and a Hawk over the Bristol Channel.
Could some nice person upload a screen shot of there settings (chart options) for PP? i seem to have cocked mine up some how and seems to not be showing a lot of aircraft, it keeps popping up saying XH558 Vulcan is around but its not showing up on the map view.
thelad wrote:Could some nice person upload a screen shot of there settings (chart options) for PP? i seem to have **** mine up some how and seems to not be showing a lot of aircraft, it keeps popping up saying XH558 Vulcan is around but its not showing up on the map view.
Your chart settings are probably fine.
Have you set an alert for the ICAO address of the vulcan? If so, the alert pop-up will show it BUT it will not show on the chart unless there is position info available (via multilateration, as I don't think it routinely transmits position data).
doing it via the reg, normaly works fine but the chart settings went back to default so I have set them up using bits and bats from other web sites, im using the online raw data.
