Liverpool John Lennon change of frequencies
2E0LGZ
Call Sign: 2E0LGZ
Post by 2E0LGZ » 11 Aug 2019, 17:48
Most of Liverpool’s frequencies have moved up 5khz from previous frequencies i.e
Liverpool Approach : 119.855 (previously 119.850)
Liverpool Radar : 118.455 ‘’’’’’
Liverpool Tower. : 126.355
Liverpool Ground. : 121.955
Whistler TRX-2
Realistic pro 2006
Various ham radios
MB6IGZ multi DV Gateway on 433.63750 MHZ
thelad
Re: Liverpool John Lennon change of frequencies
Post by thelad » 11 Aug 2019, 19:01
Should have switch to 8.33khz some time ago. Doesn't effect anybody just listening any way.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
neil57uk1
Post by neil57uk1 » 12 Aug 2019, 23:14
None of the frequencies have changed. All that has changed is the way they are identified.
Massum
New User
New User
Post by Massum » 26 Aug 2019, 09:42
The only people it affects are registered licence holders who transmit on the frequencies that are affected
Whistler TRX1. UBC360CLT. BCD396T. Icom R5. Yaesu FTA-310. TTI TSC 100R
neil57uk1
Post by neil57uk1 » 27 Aug 2019, 15:59
None of the frequencies have changed. Its only the way in which they are described.
thelad
Post by thelad » 28 Aug 2019, 04:39
neil57uk1 wrote:
27 Aug 2019, 15:59
So why has everybody in GA gone and bought new 8.33khz gear?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Massum
New User
New User
Post by Massum » 29 Aug 2019, 16:54
neil57uk1 wrote:
27 Aug 2019, 15:59
As a licenced radio holder you need to read all details.
From 3 January 2019, all ground services must use an 8.33 kHz assignment, unless they are specifically exempted.
It is illegal to communicate on an 8.33 kHz assignment if you are not using an 8.33 kHz capable radio.
From the 3 January 2019, all frequency assignments (limited exemptions listed in AIP ENR 1.8) in the UK will be operating on 8.33 kHz voice channel spacing. This includes assignments such as Safetycom and common sporting assignments.
All aircraft must be equipped to meet the legal operational requirements of the flight they are performing, this includes suitable radio equipment.
neil57uk1
Post by neil57uk1 » 02 Sep 2019, 19:37
The old 25khz spaced freqs are part of the new 8.33khz spaced allocations so the Liverpool freqs have not changed, only the way they are described.
thelad
Post by thelad » 03 Sep 2019, 04:55
neil57uk1 wrote:
02 Sep 2019, 19:37
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
neil57uk1
Post by neil57uk1 » 11 Sep 2019, 06:24
"everybody in GA bought new gear"?
Everybody?
GA?
The casual listener does at their local airport does not need to buy any new equipment.
