Can someone help to explain the Flighaware dashboard and explain what the headings mean?
I started with a cheap SDR 820T with the included antenna (not trimmed) and now have the Flighaware Stick (Inc Amp/filter) and a dedicated flight aware antenna outside and in the clear. I have increased my flights/positions three fold but nothing seems to increase in my stats. It clearly needs some explanation as to what FLIGHTS and POSITIONS actually means.
Sam
Flightaware Explained Please
- radiogaga
- Call Sign: 26TM399
30TM399 Northern Costa Blanca
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: Flightaware Explained Please
Your photobucket account does not allow for sharing apparently. Please upload an image to TM1 direct. Thanks
26TM175. OP: Craig. QTH: Tynemouth. Also 163TM175 when mobile in Wales
You say you get three times as many aircraft as before and I presume that pleases you? Do the 'statistics' actually matter?
I'd guess the numbers on the 'nearby sites' screenshot are figures from a rolling 24 hours and your station will always be the first on the list:
2211 unique aircraft
402066 position reports received in total
If those numbers are roughly the same as they were on your original setup then you can't be seeing three times as many aircraft.
