Tait T2010 Mk2
scottyboy
Tait T2010 Mk2
Post by scottyboy » 25 Oct 2017, 17:17
I got myself some Tait t2010 mk2 along with other Tait t2000 radios, I have old Tait software but believe these are requiring a newer version as I get an error of the radio type and database version are incorrect for this product.
I’m using Tait programming tool v1.08 and the radio software version is STD 0205 and database version is 0201.
Can anyone point me in the direction of newer Tait programming software?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
df2tb
Call Sign: DF2TB
Re: Tait T2010 Mk2
Post by df2tb » 25 Oct 2017, 18:16
I have Version 3.01.00. Not sure if it works for you but it might be worth a try. Send an email to andreas@df2tb.de and we can discuss how I can send it to you.
Andreas DF2TB
scottyboy
Re: Tait T2010 Mk2
Post by scottyboy » 25 Oct 2017, 22:26
Ok got the software and programmed a few radios no problem, well 1 problem is none of them will tx.
These are ex taxi radios with the data boards installed and originally worked on auto cab and auriga systems.
Reading elsewhere it was suggested that to return to conventional radios a modification needs done to disable the data system?
Can anyone confirm if this is the case?
There is nothing in the software I can see to do this.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
df2tb
Call Sign: DF2TB
Re: Tait T2010 Mk2
Post by df2tb » 25 Oct 2017, 23:39
Did you try removing the board?
scottyboy
Re: Tait T2010 Mk2
Post by scottyboy » 26 Oct 2017, 06:12
Not yet, I was hoping there was an easy way to fix it before opening it up, will get some time tonight to get a better look and open 1 up.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
radtech
Call Sign: Rich
Re: Tait T2010 Mk2
Post by radtech » 28 Oct 2017, 10:23
I seem to remember that shorting out pins 2 and 14 on the back connector with a wire link allows it to TX.
Rich
scottyboy
Re: Tait T2010 Mk2
Post by scottyboy » 28 Oct 2017, 11:37
Spot on, I found out last night that was the case and tried it. Working good now.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
