Software Kenwood TK3101 no need DOS , run to Windows !!!
rooth
Post by rooth » 15 Aug 2017, 21:24
Software Kenwood TK3101 no need DOS , run to Windows !!! :D :D :D
Interface KPG22 serial .
-Press and hold PTT and MONITOR Key (button under PTT) then switch ON the radio
-Continue to hold both buttons until the LED lights orange then release
-Press the MONITOR button the orange LED changes to RED and a beep sounds.
-Radio is now in tone setup mode !
310den
Re: Software Kenwood TK3101 no need DOS , run to Windows !!!
Post by 310den » 16 Aug 2017, 08:39
Thanks for this. Will try it later. Got to be better than using the older software via DOS. Did you develop this? Will you be doing others for similar radios?
:thumbup:
rooth
Post by rooth » 16 Aug 2017, 12:46
Hello 310den !
Last night I found the software and I successfully used it on the TK3101.
310den
Post by 310den » 16 Aug 2017, 13:21
rooth wrote:Hello 310den !
OK thanks, good find. I will be using it later.
