HDSDR problem!
Gemini4
HDSDR problem!
Post by Gemini4 » 08 Jun 2017, 09:51
Every time I try use HSDR it comes up with this?
Re: HDSDR problem!
Post by Admiral » 08 Jun 2017, 10:23
Did you do as it says? Was it working and then stopped?
ExtIO_RTL.zip
Gemini4
Re: HDSDR problem!
Post by Gemini4 » 08 Jun 2017, 19:01
I did and when I do try to start it,I get this now...
Gemini4
Re: HDSDR problem!
Post by Gemini4 » 08 Jun 2017, 19:04
It eventually starts but still no stations.
stanogs68
Re: HDSDR problem!
Post by stanogs68 » 08 Jun 2017, 20:43
this mayhelp ,also admiral has give you the file,viewtopic.php?f=3&t=53762
Gemini4
Re: HDSDR problem!
Post by Gemini4 » 09 Jun 2017, 16:09
the file does nothing at all..it's just the same..no station pick at all.
but sdr radio picks everything up,hdsdr used to but it just hisses away now..very sad as this used to be the best one.
this happens now.
Re: HDSDR problem!
Post by Admiral » 09 Jun 2017, 16:19
If you've had a Windows update recently then consider running zadig again to refresh the driver.
Gemini4
Re: HDSDR problem!
Post by Gemini4 » 09 Jun 2017, 16:38
Woo got it working with a few problems..I have to use LSB on 20mtrs this can't be right surely?
And volume very low.
nay27uk
Re: HDSDR problem!
Post by nay27uk » 11 Jun 2017, 01:59
20 meters is LSB you only go into USB from about 10 meters. Lower frequencies are generally LSB higher frequencies generally USB
M6LIG / 2E0LIG / 26TM1995
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
Re: HDSDR problem!
Post by Admiral » 11 Jun 2017, 03:28
I don't wish to sound pedantic, but for amateur use the SSB rule-of-thumb is LSB below 10Mhz and USB above 10Mhz on HF, so 20m SSB phone would generally be USB.
nay27uk
Re: HDSDR problem!
Post by nay27uk » 11 Jun 2017, 08:38
Ah OK admiral I thought it was something like that I was forgetting 20 is 14 meg
Realistic Pro 2006
Panasonic DR28-LBE
Baofeng UV5R+
YAESU FT-857D
Gemini4
Re: HDSDR problem!
Post by Gemini4 » 11 Jun 2017, 11:26
Is there any way I can get it to go louder Admiral?
Re: HDSDR problem!
Post by Admiral » 11 Jun 2017, 12:18
Apart from the obvious volume control just below the tune frequency, or making sure you have at least one AGC on when you click the ExtIO button to the right of the tune frequency (I run with both ticked) then I'm stumped mate.
Gemini4
Re: HDSDR problem!
Post by Gemini4 » 06 Jul 2017, 09:12
Got everything working sdr and now this happens!
any ideas?.
