ENTEL HX 482 UHF programing
rooth
Post by rooth » 28 Mar 2017, 15:47
Hello to all !
Please help me with some advice ... I Entel HX482 UHF radio station set programing mode .
I as want to program, and when can I find gives me error ,, No response from radio, please check connections # port .1 ,, setings set the 1 to 19200 bits per secons .Using Windows 7.
Does anyone know which pins TX RX? RS 232 serial interface using made me who works on another model.
Thanks !
rooth
Re: ENTEL HX 482 UHF programing
Post by rooth » 01 Apr 2017, 15:42
I tend to think that using the COM port interface
It is to blame for the fact it gives me error connecting PC radio.
You change Windows 7 with XP I will try RS232 interface on USB.
What do you think ?
I know I have a problem like that happened with Motorola gp340, only USB serial I managed to schedule.
He met someone that?
scottyboy
Post by scottyboy » 04 Apr 2017, 16:15
Hi, I have an entel hx483 UHF that I was looking to reprogram, would you be interested in lending or selling the cable once you have finished with it?
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
rooth
Post by rooth » 05 Apr 2017, 15:08
The cable is made of the scheme I am looking MAX232, and a jack can make telescopes wristwatch .If you think you can help try to send pictures .
moj
Post by moj » 05 Apr 2017, 15:45
Hi Scott , the easiest way I found to make the cable was by modding an icom programming cable mate , I did do a post somewhere of what the pinouts were and the connections to the icom cable that was needed etc
rooth
Post by rooth » 12 Apr 2017, 21:03
Rewritten firmware!
Complet firmware update, you should read radio still requires password.
Password seems to be put on reading radio, how could be written firmware yet?
What solutions can be found to pass the password?
rooth
Post by rooth » 15 Apr 2017, 19:52
Problem solved !
moj
Post by moj » 15 Apr 2017, 19:56
hmmm got me curious now rooth , how did you bypass it in the end ?
rooth
Post by rooth » 17 Apr 2017, 11:59
Hello ! After rewriting the firmware upload to the top left radio, change the frequencies of the table and give write .No longer required pasword ..select first reading, no need .If you have problems or do not understand something announced.
moj
Post by moj » 17 Apr 2017, 16:35
ok thankyou for that , you never know when it might come in handy in the future ;)
rooth
Post by rooth » 09 May 2017, 18:29
Interface made by me! I finally managed to program the radios!
He worked hard ... but it was worth it.
I saved a lot of money.
thebear
Post by thebear » 20 Jun 2017, 17:48
Hello guys!
I have just bought some of those walkies.. I got 4pcs. of HX482 and 4pcs. of HX482S. Can anyone help me how to program them together ?
Help would be much appreciated! :-)
thebear
Post by thebear » 26 Jun 2017, 18:58
Hello guys,
I have bought some Entel HX482 and HX482S and would like to program them so that they all work together, is there anyone who can help me with that?
// Tobias :-)
