AOR AR-DV1 - IF OUTPUT
marlbrook
Post by marlbrook » 30 Sep 2016, 10:28
In case anyone made the mistake I did.
Originally I searched the Manual for 'IF OUTPUT'. No references to that so I assumed it had not been incorporated.
In fact the AR-DV1 DOES have an IF out for use with external software, via the 3.5 mm AUX jack on the back.
I have not tried it yet, but will be doing so, as it may open a lot of other possibilities.
Andy
Re: AOR AR-DV1 - IF OUTPUT
Post by Andy » 06 Jan 2017, 13:17
You may find it only works on certain bands. I have the AR5001d and because it uses direct sampling up to 25 MHz, there is no IF up to this frequency. Above 25 MHz, the IF output works a treat.
'SOMEONE GET ME A SAW!'
Andy.
