Help with crash
nokiaman2002
Call Sign: 2E1GXT
Re: Help with crash
Post by nokiaman2002 » 25 Oct 2016, 18:20
2E1IIP
Re: Help with crash
Post by 2E1IIP » 25 Oct 2016, 18:49
I managed to recover a PC from this devil, reboot in to safe mode and do a system restore to a day or two prior to the infection, run Malware bytes once the restore has finished and you should be good to go.
Stick to Pornhub or Redtube, the others are riddled more than the porn stars in the videos! ;)
stanogs68
Re: Help with crash
Post by stanogs68 » 27 Oct 2016, 19:05
2E1IIP wrote:I managed to recover a PC from this devil, reboot in to safe mode and do a system restore to a day or two prior to the infection, run Malware bytes once the restore has finished and you should be good to go.
haha thanks for the advice (on the computer not porn sites :D )i tried system restore and its says can"t do it ,something like sys mgr missing or something ,what i was i went in sys config to try and stop this virus loading and must of stopped a boot file from loading and i dont have windows 7 disc as it came loaded :oops: ,i have a new one now on windows ten but feel like buying another cheap one running widows 7 can,t get my head round it :? :? :D
ClubbaUK
Re: Help with crash
Post by ClubbaUK » 30 Oct 2016, 11:18
The virus will be loaded via the registry not the sys config.
Unless you know how to access sys.cfg in repair mode (so you can undo the additional problem you created) you are not going to get anywhere and no amount of advice to remove the virus will repair what you have done yourself.
2E1IIP's advice would have possibly fixed it for you otherwise.
stanogs68
Re: Help with crash
Post by stanogs68 » 31 Oct 2016, 12:55
ClubbaUK wrote:The virus will be loaded via the registry not the sys config.
i would have done that but didnt have the advice when i went at it myself(my own mistake) :oops:
stanogs68
Re: Help with crash
Post by stanogs68 » 31 Oct 2016, 19:34
nokiaman 2002 that sounds ace but very much out of my small expertise ,but thanks ill read up :thumbup:
ClubbaUK
Re: Help with crash
Post by ClubbaUK » 01 Nov 2016, 02:07
have you tried running it in safe mode? if so does the desktop come on?
stanogs68
Re: Help with crash
Post by stanogs68 » 02 Nov 2016, 12:09
its starts to load up gets to that little square that scrolls does then for 3 seconds flashes and starts again (repeat etc ) if you know what i mean it looks like its going to flash windows on then flashes and restarts the same procedure but yo canstop it just before that with the F buttons
ClubbaUK
Re: Help with crash
Post by ClubbaUK » 02 Nov 2016, 23:30
If you can stop it with the Fkeys use F8 just after the boot 'beep' and select safe mode (might take a few attempts)
If you can't get it into safe mode then I can help you no further and you'll need to get Win7 re-installed or get a local PC repair shop on the case.
stanogs68
Re: Help with crash
Post by stanogs68 » 03 Nov 2016, 11:52
i can stop it with the fkeys but when i try and boot safe mode it just does the same thing keeps jumping off when its about to load then repeats the same over and over ,so it must be windows itself do you reckon !!
ClubbaUK
Re: Help with crash
Post by ClubbaUK » 11 Nov 2016, 13:12
Sorry for delay in responding, I've been rather busy.
Sometimes a boot repair can be done with the win7 recovery/repair disc but you altered the sys.ini file which has changed the whole game.
It would be better & straightforward to do a fresh Win7 install and a lot cheaper due to labour costs (if you're paying someone to do it).
stanogs68
Re: Help with crash
Post by stanogs68 » 11 Nov 2016, 21:12
thanks clubba but i didnt want to pay for a re-install on a oldish computer ,i just wanted to rescue it because it run windows 7 i have no disc as it came installed so its not worth it ,i have a new laptop on windows 10 but i find it difficult ,i just wanted my old computer on windows 7 ,thanks for the reply :thumbup:
stanogs68
Re: Help with crash
Post by stanogs68 » 13 Nov 2016, 17:30
:D Has anyone got a copy of windows7 I would be gratefull :D. Cheers
2E1IIP
Re: Help with crash
Post by 2E1IIP » 13 Nov 2016, 18:06
stanogs68 wrote::D Has anyone got a copy of windows7 I would be gratefull :D. Cheers
I can put an iso image in my Google Drive so you can download it and burn it to DVD if you like?
stanogs68
Re: Help with crash
Post by stanogs68 » 13 Nov 2016, 18:08
sorry 2e11p im not sure what you do thanks for being nice if you can talk me through i would be well chuffed cheers mate
