sdr sharp- vac
sdr sharp- vac
I am using sdr sharp on my windows 7 lap top...my problem is I have downloaded virtual audio cables into sdr folder , but when I run sdr sharp I canot see them in there my other pc is windows 7 premium and v.a. c....... works well on there I have tried deleting and reinstaling with no joy.....
Re: sdr sharp- vac
problem solved...............................................
Re: sdr sharp- vac
What did you do?
Re: sdr sharp- vac
sorry for the late reply.. i deleted vac again and reinstalled it for the third time and it worked for some reason.
Re: sdr sharp- vac
Aye, had me scratching my head... Ended up using VB Audio Cable.
Re: sdr sharp- vac
so is it working for you now...are you decoding a lot of dmr ........i am getting dmr coming through loud and clear but strugelling with d-star.
Re: sdr sharp- vac
Not using DMR..... Just needed to transfer the audio, but VB Audio seems to work OK.
