Guys help ??!! got one off these " cosycave " dongles that I have plugged into my pc and running sdr# software, although I don't use te dongle a lot whenever I run the software / dongle its works perfectly that is until up to today, when I plug the dongle in and run the sdr# software I get the message " rtl /sdr /usb is either not connected or its driver is not working properly "
any ideas ?
sdr# not working now ?
- gmham
- Call Sign: 108TM154
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Warden
- Call Sign: 26TM612
Re: sdr# not working now ?
Try another usb port. Or try rebooting your PC.
26-TM-612
No one rules if no one obeys.
Winner of the amazing In before the lock game 09/09/14
- gmham
Okay cheers but unfortunately still nothing, when I plug the dongle in on the pc I cannot hear the pc recognising that there is something being plugged in ie usual recognition noise is not heard , should the dongle it show up within my computer ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- Blackpirate
- Call Sign: 26TM034
restore your computer to a earlier point when the dongle/SDR was working...
you,be lost the driver by the looks of it...
worth a try
worth a try
Operating close to the edge......of the Quantock hills..!!
qrv on 27.635 in RoS......
- gmham
Okay cheers can I just download the driver software again if so anyone got a link ? been that long since I initially set up my dongle / software bit lost with it all.
also I got it wrong when I plug the dongle into the usb port off my pc yes I do hear the regular recognition noise but then that's it,argh ??!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Okay tried a system restore but still no joy, was going to try and uninstall sdr# and start again but cant even see it within my list off installed programmes ?? the sdr # icon is on my pc desktop with all the associated files within. so anyone fancy helping this pc numpty with installing the driver again or even uninstalling everything and starting from scratch ??!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Quick update - found zigzag and pressed install driver= all working again !! thanks
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
