Hi,
Does anyone know how i can get my pc to recognize my radio without the drivers?
i have searched the internet for them, but cannot find any .
My radio is the Icom ic-737 made in 1993 according to icom-uk, but icom do not have them due to it being discontinued some years back, they only have the manual and service guide on disk now which i already have, but not the drivers.
Best regards and 73's
Gary.
Radio drivers for pc ???
- Call Sign: 26CT1077
Respect has to be earned, without Respect your a nobody.
- GW0DIV
- Call Sign: GW0DIV
Re: Radio drivers for pc ???
What drivers?? CI-Vis a serial port system, a USB CI-V uses the drivers for the particular serial to USB device in the lead. What are you trying to do? With what hardware? And what software? ?
http://www.facebook.com/southwalesradio
http://www.radioclubs.net/rars/
Twitter: @GW0DIV
President of Bristol Channel Repeater Group
Twitter: @GW0DIV
Hello,
What i want to do is connect my radio to my computer so that i can use SSTV and remotely use other options, but my computer does not recognize the radio, so therefore i cannot do what i want to.
Every time i plug the radio into the comp it tells me to download the software manually because it cannot do it automatically.
- GW0DIV
- Call Sign: GW0DIV
What CI-V interface are you using and what audio/PTT interface?? Does the CI-V interface have the prolific or FTDI chipset? Are you using windows 7?
Twitter: @GW0DIV
Twitter: @GW0DIV
Hello mate,
its an old used one i bought from ebay, it uses a FTDI chip set and was assured it worked ok, i'm currently using windows 8.
- GW0DIV
- Call Sign: GW0DIV
it may be faulty?
Have you tried the drivers here:
http://www.ftdichip.com/FTDrivers.htm
It is also possible you have a faulty CI-V port on the radio?
Do you have serial ports on your PC? If you do a serial lead is so much more reliable. I put a serial card in my PC just to use with the radios.
Twitter: @GW0DIV
Twitter: @GW0DIV
Hello,
Apologies for a late reply, been in hospital. yes took my radio in to the shop and your right the radio was at fault, £37 put it right, now all is working.
Many thanks and 73's
Gary
Gary
