Motorola GM900
- Mad4radio
Motorola GM900
Hi,
Can anyone tell me if its a different cable I need to program the gm900 to what I use on the gm300's??
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
Re: Motorola GM900
Different cables.
GM950 RIB to Radio
GM300 RIB to Radio
the radio connections are not the same.
GM950 RIB to Radio
GM300 RIB to Radio
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
- Mad4radio
Re: Motorola GM900
Wounderful pal thanks ever so much for clearing that one up for me :-)
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
Re: Motorola GM900
just noticed that the pic is for the gm950...
it is still different from the gm300
here is the mcs2000 / gm900
HF
VHF/UHF
Antenna
Data Interface
QRZ.COM
- Mad4radio
Re: Motorola GM900
Defo need another cable then ?? (Agreed) thanks for the research pal very much appreciated :-)
- mm3dka
Re: Motorola GM900
Hi Lads, I got an rj45 to usb and installed the drivers provided. OK I had to use my
vista os computer. I was using gm350 programme and I connected cable to my
gm950 hey presto an error came up but when I pressed IGNORE the radio was read.
then I connected a gm350 to cable and told computer to wright to radio it wrote the channels from gm950 to the 350. i'm now just starting to delve deeper seting squelch,
mic gain just for starts....John
PS.. get the com port setup correctly to save a lot of headbanging lol
pps.. got 2 gm900's comeing next week
108-TM-029..108-CT-029..108-KI-029
--Kucha Hans moded Anytone at5555v3.1-ic7400-FT 847-
--ic-e 2820 dstar-philips 8020-4mtr-philips fm1000-4mtr-Philips fm1200-4mtr-
--Motorola GM350 x2, GM950, GM900. Vertex Standard VX-4204E-
- mm3dka
Re: Motorola GM900
Yes Bill you are correct, my gm350 and gm950 programming leads are not the same as the gm300 and gm900, I've tried but not long enough to start pulling hair out lol. its quite easy to get gm300 and gm900 cables off ebay. I think they are the same ones that fit 300's and 900's. cheers...John
- mm3dka
Re: Motorola GM900
I know have 3 gm900 and none of my gm350,gm950 cables are wired for them. I have now bought a cable for gm300 and have the programmes. I'm now going to programme them when I get the software. LUCK FORBIDDING LOL...cheers...John
- Mad4radio
Re: Motorola GM900
Still seeking the rss for the gm900 if anyone has a copy??
Thanks in advance guys
- Mad4radio
Re: Motorola GM900
Hi,
I'm after identifying the 25 PIN numbers on the gm900 as everything I come across states what the pins do but nothing in regards to the way the pins start from 1-25 if that makes sense as I'm wanting to interface one upto the M0AQC interfaces to control ptt,
Searching the net they's plenty info on the gm300's in regards to pics identifying the PIN numbers but nothing in relation to the gm900.
I'm hoping some of you guys can advice me or point me in the right direction :-)
