Does anybody know how i could record the audio from my Icom IC-R5 on to my computer because i have no idea?
Thanks all
Jonathan
Record Audio
Radio Recorder
If you follow the same instructions re the 3.5mm lead as previously mentioned then download the below freeware
http://www.davee.com/scanrec/
This has a squelch to allow the recieve audio threshold to be set
after a bit of tinkering with it you will find it far more useful than the windows recorder
It will only then record when a tx is recieved thus saving disk space
i use this and it is very good
Andy
2E0AIV
Andy
2E0AIV
Hi, never connect headphone jack to - MIC IN - unless a pair of resistors are used to lower the power ratio by 10 : 1 to .01volt max.spike wrote:I'm assuming the IC-R5 has a 3.5mm headphone out jack.
I'm also assuming that you have Windows on your system.
You'll need a 3.5mm jack to 3.5mm jack cable (http://www.maplin.co.uk/Module.aspx?Mod ... =&doy=27m1).
Connect the two devices together. Output from headphone jack on IC-R5 to the line input (or mic in) on your PC.
By far the best recording program i have found is Xcorder
The creator seems to have a problem at his site but i can supply a direct download from my own. simply connect your scanner to the input and when the squelch opens it records.
I will supply the site address even though it appears to be faulty
http://www.xcorder.com/
Download it from here
http://uk.geocities.com/andygoole/xcorder.zip
GRE PSR-255
Oregon Scientific TP329 (x2)
AOR ar8200 (sold)
Alinco DJ-X3e
Realistic Pro2006
Uniden UBC75XLT
Uniden UBC3500XLT
Baofeng UV5R + Qualette (Blue)
Baofeng Bf-888s (x2)
Baofeng UV-5B
Licence: Short Range VHF Marine
Licence: Simple UK Light
AOR ar8200 (sold)
Alinco DJ-X3e
Realistic Pro2006
Uniden UBC75XLT
Uniden UBC3500XLT
Baofeng UV-5B
- New User
Xcorder download
Hi everyone.
Ive uploaded Xcorder to a file host for everyone who cant get the download.
Here is the link http://www.mediafire.com/?682nghya1bq
Enjoy!
Callan
Enjoy!
Callan
