Albrecht 2990 super radio ss301 handheld ssb audio
- Call Sign: 26tm543
I recently got hold of a super radio ss301 ;(albrecht2990 ) for a play about on hills etc .I have done the anti jitter audio mod with a 1mf tantalum cap and a 10k resistor but it still warbles like a canary on ssb tx even with mic gain right down .Has anyone successfully modified on if these to actually be usable on ssb or are they just a lost cause and destened to be a fm am handheld with ssb Rx as that's all it is really
ssb is for life
- slamjam
- Call Sign: 26DT871
Re: Albrecht 2990 super radio ss301 handheld ssb audio
does it still warble on an external 12v supply? I suspect it might be to do with an inadequate voltage source
26DT871 - Ipswich UK
Yes I'm using a 50 amp PSU with a 10amp cig plug outlet using the Midland battery iliminator .So supply voltage and current should be well beyond whats needed for this handheld
ssb is for life
Fix that garbage http://www.cbradio.nl/abrecht/Service_M ... ENG_DE.pdf
Like I said in my post it's already had that done I did it as soon as I got it
ssb is for life
Sorry, reading on dumbphone. So you have a voltage drop somewhere. I would measure it on mainboard under load.
- k40
- Call Sign: 26TM788
But they are rubbish, I was glad to see the back of mine.
- dt307
- Call Sign: 163dt307
had 1 in with the same warble did the mods listed and was better, was a few years ago and was the newer version that was ment to be ok .....my ass was ok, reduced mic gain and stiffened up the vco supply got it sounding better.
going from memory and i am like a fish ..... i added an extra cap same value 47uf i think to the supply of the vco but there was no room to add it so i added it on the regulator end by the 2 filter caps ... wasnt for the faint hearted.
sent it to my m8 jan in thailand and he says it works great.
these radios are just crap
163dt307-chris
― Albert Einstein
― Albert Einstein
Cheers for that will give it a go
ssb is for life
The handheld radio is dog **** awful warble on audio and awkward to use
