different models Ranger RCI-2995DX ?
- ballo
- Call Sign: 19DD03
Hello all,
I looking for a Ranger RCI-2995DX and i see RCI-2995's with a green display and with a dark display to show freqeuncy.
Are there different models of the RCI-2995 ?
http://www.pa3hgt.nl
President Veep 40 ch am/fm , President Jackson Classic 6 bands ,HAM International Jumbo 3/Multimode 3/Viking 3,Midland 7001 MK3,President Jackson 2 chrome/JFK Chrome/Lincoln/HR2600/Franklin,Dirland DSS9000F,Petrusse Ecalibur 2002.
Re: different models Ranger RCI-2995DX ?
Don't have one , but there's a DIM button on the front which adjusts the back lighting . Isn't it just that ?
- ballo
- Call Sign: 19DD03
I was thinking the same but i am not sure. I know that the 2970 series has a "new" model with a dark display.
- dt307
- Call Sign: 163dt307
there is a few different revisions early ones had normal display and later ones had the lcd reversed .
as for the mainboard i have worked on a few but cant recall if 1 version was normal and 1 was smd
163dt307-chris
― Albert Einstein
― Albert Einstein
Problem solved . Thx Chris .
There's a thread on here somewhere on how to reverse the led on the Lincoln as well . Never done it myself .
- ballo
- Call Sign: 19DD03
Thanks for the info,Chris !
- slamjam
- Call Sign: 26DT871
The green display were the early ones then the LCD was reversed. The black display ones came out around 6 or 7 years ago. The Green ones maybe ten years ago.
26DT871 - Ipswich UK
- beamer320i
Early models had a smaller first digit on the frequency read-out like the 2950/2970 mobile units with a green display. Next revision had 'full figure' frequency read-out with a green display, and the next revision had the reversed LED readout mentioned above, before the latest model, the 2995DXCF (cooling fan).
Early models had PSU problems, later models had MOSFET's which aren't to everybody's liking. If you're looking at a particular one, check out the first three numbers on the serial number for the date of manufacture, for instance - Mine is T707xxxxx, year/month so was made in July 2007 meaning it has the twin Toshiba 2SC2290 finals. I think they changed to the later MOSFET/reversed LED model in about 2011.
I've just noticed that now in the 2 photos . Specsavers for mebeamer320i wrote: ↑09 Apr 2019, 15:36 Early models had a smaller first digit on the frequency read-out like the 2950/2970 mobile units with a green display. Next revision had 'full figure' frequency read-out with a green display
- ballo
- Call Sign: 19DD03
Thanks for the extra info , the serial is starting with a "T " so that's a Toshiba 2SC2290 model ?
- ballo
- Call Sign: 19DD03
I asked the seller and the Ranger has Serial T8020XXXX so think i have the twin toshiba's too !beamer320i wrote: ↑09 Apr 2019, 15:36 Early models had a smaller first digit on the frequency read-out like the 2950/2970 mobile units with a green display. Next revision had 'full figure' frequency read-out with a green display, and the next revision had the reversed LED readout mentioned above, before the latest model, the 2995DXCF (cooling fan).
- beamer320i
Excellent! That era model is the best one to get, twin pill output and decent PSU. Go get it!
- ballo
- Call Sign: 19DD03
I bought it Thanks for your quick reply !!
- ballo
- Call Sign: 19DD03
Is it possible to set the repeatershift at +90 Kc with the 2995 ? , we have in the Netherlands a CB-repeater ( https://cbrepeater.nl ) with approx. 60% coverage of our country.beamer320i wrote: ↑09 Apr 2019, 15:36 Early models had a smaller first digit on the frequency read-out like the 2950/2970 mobile units with a green display. Next revision had 'full figure' frequency read-out with a green display, and the next revision had the reversed LED readout mentioned above, before the latest model, the 2995DXCF (cooling fan).
