Ok I got the power cable for the Alan (Midland) today plugged it in and nothing
had a quick check on the fuse, it was fine, open it up all looks fine no sign of damage so put it down to being a duff box
but when I went to pull the power connector out I noticed the polarity markings and realised the plug was wired wrong
swapped the polarity over and she sprung to life
after a quick check it seems to have everything from 26.000 to 30.190 and the main 40 CB channels as well as the A channels
here's the bands in the order they come up
Band A - 28.000 - 28.490 - 50ch
Band B - 28.500 - 28.990 - 50ch
Band C - 29.000 - 29.490 - 50ch
Band D - 29.500 - 29.990 - 50ch
Band E - 26.000 - 26.490 - 50ch
Band F - 26.500 - 26.990 - 50ch
Band High C - 26.965 - 27.405 - 40ch +a
Band G - 27.000 - 27.490 - 50ch
Band H - 27.500 - 27.990 - 50ch
Band I - 30.000 - 30.190 - 20ch
I've called it "High C" as the other bands are in lower case its a capital C
all in all its a tidy box that seems to be working well
Alan 9001 with 10 bands ??
- oldpink
I hear Radio Waves in my head
CRT SS 6900 Fully modded Export setup programmable
Cobra 148 GTL DX Mk 2
Alan 9001 26 - 30.190 multi band
SDRPlay RSP1A x2 with a Create 5310 on a rotator and Discone for general
108-TM-046
108-TM-046
- 14CS06
Re: Alan 9001 with 10 bands ??
- oldpink
thanks
I'll check to see if its been modded as above
108-TM-046
108-TM-046
- astradyne
Good radio's. As Claude said they're the same as the Emperor Shogun and TS5010. They have a battery to hold the memory channels when the radio is disconnected from its power source. It may be worth checking it to make sure it's still good.
- 14CS06
- oldpink
thanks I'll replace it as they are pennys
not got into programming it yet but I can see the advantage as I'm monitoring the Uk fm as well and its an odd frequency
108-TM-046
108-TM-046
- CaptainKirk
- Call Sign: KIRKY
Some Alan 9001s only go down to 26.500 not 26.000
CAPTAIN KIRK-26TM013/26CT013/26UK013 John mobile South Cheshire.
- 14CS06
Hello
version 1 - 1993 go down to 26.500
IC0170505B
614081SE11
4D1 JAPAN
version 2- 1994 go down to 26.000
IC50200505
HD614081SE37
4K1 JAPAN
IC0170505B
614081SE11
4D1 JAPAN
IC50200505
HD614081SE37
4K1 JAPAN
I have the Shogun version. Didn't know about the battery , as I haven't used the memory. So thanks for that.
