Uniden Uniace 300 serial numbers
Have recently picked up a Uniden Uniace 300 homebase CB (one of the locals got it from Knights a month ago) the radio has the dark green strip at the front along the bottom.The serial number of my radio is 73 000087 and was manufactured in Taiwan R.O.C.
Spoke to Reiner in south west Germany yesterday,on UK Ch21 or 27.801.25 Fm with this radio
27.555 Usb
27.555 Usb
Re: Uniden 300 serial numbers
I remember ordering mine from the CB shop in Largs when they were first released . Can't remember the exact year . Maybe 83/84 ? I was a bit disappointed when I opened it up to find it had the same pcb as my Audioline 341. Anyway , I still had lots of contacts with it , and lots of fond memories using it .
...and not to be confused with the crappy-boarded KP77.
I had the Uniden and Audioline homebases back in the day, but found they were a bit too deaf compared with my Fidelity homebase when talking long-distance. They were probably 10 times more reliable though admittedly, although my Fidelity's still going strong nearly 37 years on.
- astradyne
Those KP77's are just terrible. Back in the day plenty of folk bought and used them in the belief that they were just a rebranded Audioline 345. How mistaken they were. Anyhow, I have a Uniden 300 here. It's one of the later ones with the black inlay behind the controls and the modified PCB with a crystal filter replacing the ceramic one used on the older boards. Not sure of the serial number. I'd have to dig it out to check.The Collector wrote: ↑25 Dec 2018, 15:34 ...and not to be confused with the crappy-boarded KP77.
Were there 2 different-coloured inlays, or did the black one just turn green with age/UV rays...or was there an Uniden 300 and also a separate "Uniace" version if I recall correctly (I'm probably wrong though as I don't collect homebases)?
- astradyne
The older original Uniden Homebase, the Uniden "Uniace 300", has a bottle green coloured inlay behind the controls. The later version, the Uniden "Uniden 300", has a black insert behind the controls.The Collector wrote: ↑25 Dec 2018, 21:54 Were there 2 different-coloured inlays, or did the black one just turn green with age/UV rays...or was there an Uniden 300 and also a separate "Uniace" version if I recall correctly (I'm probably wrong though as I don't collect homebases)?
Not sure if this was in keeping with the black fronted 100's and 200's which came into production at the same time, but it would make sense if that were the case. The later Uniden's were also built in the Philippines.
Ahhh.. I say that because there's a "Uniace" homebase that's got a black inlay on it on ebay at the mo.
I know some of the old radios like the Realistic TRC2000 had a black front that slowly turned a bronze colour from uv rays and so did some JWR's amongst others.
- astradyne
Is this the one you mention?
https://rover.ebay.com/rover/0/0/0?mpre ... 4104047926
It's definitely got the lighter green insert along the bottom. I don't think the photo's show it very clearly though. Compare these images of the one in the above link (the Uniace) and the later model. You'll see a clear difference.
Yeah, that's the one above.
I've seen the greeny-coloured panels before but assumed at first that they might have faded from black to a grey-green. I couldn't see why they'd introduce green, but I've seen worse colour combinations before now. I suppose the best way to prove it was green originally would be to find NOS ones and to look at the strip on each. The old magazines probably wouldn't show them clearly enough, plus most pictures of them would be in B&W in the central pages.
Cheers.
Cheers.
- 14CS06
Hello
Please look at this old magazines
https://www.flickr.com/photos/88011785@ ... 1682553112
From lambrettadave
PCB PA-096AA
From lambrettadave
PCB PA-096AA
Thanks Claude / Dave.
You can see the panel is lighter than the black front itself even in the mag' article, although it looks more grey than green on the ebay one pictured above. I suppose they're easily swapped over anyway as they look identical bar the colour.
Sorry for taking this off-topic a bit by the way
Can't easily get Taiwan on the backThe Collector wrote: ↑27 Dec 2018, 11:32 Thanks Claude / Dave.
27.555 Usb
27.555 Usb
