Firestik 2 threaded ajuster too short
original45
Call Sign: 45
Post by original45 »
Got a 5' firestik 2 with the threaded swr adjustment at top. It's slightly too short as it spears swr would drop further if I didn't run out of threads on standard rod.
Seems a strange course thread anyone found suitable rod to replace or had this problem. I'm guessing 1/2" extra would suffice.
Call Sign: Lemmy
Re: Firestik 2 threaded ajuster too short
Post by ch25 »
Maybe it is mounting location influence.
original45
Call Sign: 45
I will try it again Chris, but it is the second attempt with it as I now have a suitable 3/8 magmount ,the last test was on a friend's mag but I'm getting same on mine.
Don't get me wrong it's ok but I know if it were longer I'd get even lower.
Will try again in the week.
Cheers again chris
Tim
Call Sign: 26AT239
Post by Tim »
Sounds like by what you say that some previous has cut the threaded end to SWR instead of the other end of it. Find a length of steel or brass wire the same dia and thread it to the length you require with an appropriate thread die.
Tim
Call Sign: 26AT239
Post by Tim »
Clipper
Post by Clipper »
You can get 3/8" x 24tpi couplers on ebay which can add the length at the bottom on the antenna. Example (BPN30) here
The nut that comes with a lot of 3/8 threaded antennas is meant for adjusting length at the bottom too.
Tim
Call Sign: 26AT239
Post by Tim »
The threaded stud length at the base makes no difference to the SWR adjustment as it's below the coil and has no influence on the electrical length of most mobile antennas.
Clipper
Post by Clipper »
It's all one radiator - why do centre/top loaded antennas work?
The Collector
Post by The Collector »
Tim wrote: 05 Dec 2018, 09:14 The threaded stud length at the base makes no difference to the SWR adjustment as it's below the coil and has no influence on the electrical length of most mobile antennas.
So one of these wouldn't make any difference then?
https://rover.ebay.com/rover/0/0/0?mpre ... 0830120834
It's the only reason I can think of why someone would buy one :)
Tim
Call Sign: 26AT239
Post by Tim »
That GP unit would do absolutely nothing for the radiation pattern, your vehicle is the ground plane, if anything it would probably upset it.
The Collector
As it screws onto the aerial itself rather than the magnetic base/ground-plane, surely it shouldn't noticably affect the radiation pattern?
I was thinking if it physically added an inch onto the height of the aerial, it might mean the top-screw could then be adjusted more.
original45
Call Sign: 45
Anyone know what thread size type it is on the ajuster rod please
