New house, new shack, new antenna?
108EH002
Re: New house, new shack, new antenna?
Post by 108EH002 » 30 Aug 2018, 19:35
^^ You forgot to mention the A-99 is in a lead safe ;) ^^ :lol:
You can talk worldwide on CB not 10 - 15 miles,
Many freebanders know otherwise = test free.
27.555 Usb
Post by The Collector » 31 Aug 2018, 14:15
If I could get away with hoiking up a Siggy4, I may actually be able to converse with someone ;)
108EH002
Post by 108EH002 » 31 Aug 2018, 18:23
Second hand Imax painted the same as your 99 Collector,and if anyone notices the big brother,you just put the old one up 8ft ;)
27.555 Usb
Post by The Collector » 31 Aug 2018, 21:54
I sold an Imax I'd bought a year or two back as there was no way I could hide it like the Antron (had bought it for exactly that reason). It would have stuck up nearly 10ft above the conifers whereas the Antron is only about 3ft and just looks like the central part of the conifer. I might be able to get the Antron up a couple of extra foot, but that'd be really pushing it ;)
GusWroclaw
Call Sign: 161TM313
Post by GusWroclaw » 10 Oct 2018, 15:24
radiogaga wrote:
29 Aug 2018, 15:07
I wouldn't even entertain a vertical but instead look at running a loop (if the garden is square) round the garden.
I wonder, what's the reason for avoiding a vertical? Is there something specific to OP's situation or do you avoid vericals in general?
161-TM-313 - Midland Alan 42
GaryWilson
Call Sign: 2E0GGQ
Post by GaryWilson » 21 Oct 2018, 12:19
GusWroclaw wrote:
10 Oct 2018, 15:24
radiogaga wrote:
29 Aug 2018, 15:07
Gus, vertical antennas are much more susceptible to electrical interference, that's why the loop was suggested.
73's Gary.
26CT1836 2E0GGQ
GusWroclaw
Call Sign: 161TM313
Post by GusWroclaw » 21 Oct 2018, 12:43
GaryWilson wrote:
21 Oct 2018, 12:19
73's Gary.
Thanks Gary, good to know. And is it the case that even a vertically polarized loop is better than a vertical in this case? Or is it vertical polarization in general what needs to be avoided in this case? I wouldn't mind reading more info on why verticals are so bad if you have a an explanation or a link to an explanation. :geek:
GaryWilson
Call Sign: 2E0GGQ
Post by GaryWilson » 03 Nov 2018, 07:06
GusWroclaw wrote:
21 Oct 2018, 12:43
GaryWilson wrote:
21 Oct 2018, 12:19
73's Gary.
Gus, sorry for the delay replying. Most electrical interference will be polarised horizontally so any antenna which has a vertical element to it will be prone to picking up those signals. It is widely accepted that horizontal antennas are less noisy because of this. There are considerations though if you are working local stations that are vertically polarised you will see a big reduction in the wanted signal if you are horizontally polarised, if you are working DX/skip stations then this is much less relevant and horizontal becomes beneficial because of the reduced noise received.
73's Gary.
26CT1836 2E0GGQ
