Noise cancelling speakers
DX Duster
Post by DX Duster » 28 Aug 2018, 10:44
Hi guys I’m after opinions on the bhi range or does anyone have experience of any good noise cancelling speakers
Carl
Call Sign: n0call
Re: Noise cancelling speakers
Post by ch25 » 28 Aug 2018, 11:28
Snake oil if you ask me.
Buick Mackane
Post by Buick Mackane » 28 Aug 2018, 11:43
I have the BHI Noise away unit, I forget the model number, Anyhow when i first used it i thought it was the best thing since sliced bread, But after using it for a while iv'e came to the conclusion its nothing more than an ''auditory trick'', It does make listening a bit less harsh on the ears especially under QRM conditions,
Iv'e also noticed that it lowers the tone of the incoming audio, So stations with deep audio can sound muffled.
You can get the same unit that installs directly inside your radio, But mine is external, Which means i can use it on any radio,
Are they a cure to all ill's ? The answer would be a big fat NO
5/9 QSB Via The bureau :yawn:
Post by The Collector » 28 Aug 2018, 18:34
Those FM Cruncher noise filters in the 80's were reputed to be quite good, but I'm not sure if they'd work on other modes??? They apparently cut right down on the hissy white noise.
You could always create your own filter by wrapping an old sock around the speaker and putting a piece of cheese in your ears ;)
