Tristar 747 RX problem
pat
Call Sign: 29LR001
Post by pat » 04 Aug 2018, 17:00
Hi men
I have acquired a tristar 747 to use for my 11 meter stream.
While the TX is fine, the same can't be said about the RX,
It seems to be too strong, (audio distorted )
Would anyone know if this is an easy fix, EG turning a pod to reduce the sensitivity.
It has been moded already, wide banded, UK FM, 10kc shift, 5kc shift roger bleep (which was the LOC/DX button)
Thanks in advance
Pat
29lr001
Black Spirit
Re: Tristar 747 RX problem
Post by Black Spirit » 04 Aug 2018, 17:29
Is it too harsh on all modes or just SSB ? Its possible some golden screw driver has turned the AGC too high
pat
Call Sign: 29LR001
Post by pat » 04 Aug 2018, 18:19
Many thanks Black Sprit.
I will have a go at this,
You can swl my stream here : http://dx27.net/dx27cluster1/stream.php
pat
Call Sign: 29LR001
Post by pat » 04 Aug 2018, 18:48
SO, it was turned full clock wise.
I have backed it up to 10 o clock, seems to be okay,
Thanks again,
Pat
