Alinco DR-135UK programming problem?
liamhere
Call Sign: M6TVI
Post by liamhere »
using windows 10
got a lead and software all drivers are good
reads radio....then i want to add my dat file for channels
writes to radio say end all is good
turn off the radio and it just says 28.000
i know about band 1 and 2 but my list isn't staying on the radio :(
help please if you can
Liam
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
radiogaga
Call Sign: 26TM399
Re: Alinco DR-135UK programming problem?
Post by radiogaga »
Appreciate you know about band 1 and 2 but it does sound that it’s stuck in band 1. You have to hold the function key longer than you think. If that fails you are welcome to my dat file to try?
Does changing channels move it up through 10m?
30TM399 Northern Costa Blanca
liamhere
Call Sign: M6TVI
Post by liamhere »
how long on the function button?
yes would love your dat file if you don't mind :)
no its stuck on 28.000
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
radiogaga
Call Sign: 26TM399
Post by radiogaga »
No worries I’ll work a way out to send it.
When you say stuck, it won’t go anywhere else, right?
If so read the dat file from the radio, what do you see.
You know there a bit of truck with th software that I found
1. Make sure radio is off and UNPLUGED, with the USB cable plugged into the computer, you’ll have a flying mini usb.
2. Start the software
3. Wait a few seconds plug in the mini usb to the radio
4. Turn on radio.
5. Wait a few seconds
6. Read radio DAT
Let us know if the screen goes to PC and it reads. I’m only new to the DR135 but spend a few hours on it. The above was and still is only way I can get it to read reliably. Where did the out get the cable? A mate of mine bought one from eBay and it would not write. Mine did, he ended up with a replacement and it was fine... Lets elimate the obvious first
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Oh function button about 5 seconds. Try that before reading dat
liamhere
Call Sign: M6TVI
Post by liamhere »
I'll try this tomorrow now....thank you for your help
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
radiogaga
Call Sign: 26TM399
Post by radiogaga »
Welcome. I’ll sort the dat tomorrow too
liamhere
Call Sign: M6TVI
Post by liamhere »
ill pm my email if that will help :)
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
liamhere
Call Sign: M6TVI
Post by liamhere »
my cable was off the bay too.....from a person in cornwall....i think you will know who i mean.
where did you get your from?
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
liamhere
Call Sign: M6TVI
Post by liamhere »
your step by step guide worked....thank you :)
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
radiogaga
Call Sign: 26TM399
Post by radiogaga »
:thumbup: :thumbup: :thumbup:
liamhere
Call Sign: M6TVI
Post by liamhere »
26-TM-928
26-CT-928
26-FB-928
26-DR-928
NR-928
kenwood TS 480Sat
