sirio gpe27 5/8 wave
gmham
Call Sign: 108TM154
Post by gmham » 28 May 2018, 19:50
Guys Sirio GPE27 5/8 wave version requires the top rod section to be set for swr depending on freq ( chart supplied ) any other owners off this antenna advise me where this measurement is taken from ? from where the rod exits to the bottom off the collar that holds the static ball or to the very tip off the antenna just below the static ball ( at top off collar ) ?
Icom IC7300 HF /6 mtrs
Kenwood TS711E 2 mtrs ssb
108-TM-154 - John
Mudslinger
Re: sirio gpe27 5/8 wave
Post by Mudslinger » 29 May 2018, 17:05
I think it is from the top of the collar to the top of the ball, but without looking at the instructions I cannot remember.
gmham
Call Sign: 108TM154
Post by gmham » 29 May 2018, 17:33
Okay thanks Simon .from looking at the image in the following link it looks as if it could be just below the ball as you say.just thought I would check ?
https://www.google.co.uk/search?tbm=isc ... chVzvy04jM:
108-TM-154 - John
Mudslinger
Post by Mudslinger » 29 May 2018, 19:06
I cannot remeber for sure, it was years since I put the antenna up. You may have to try measuring below the ball and see what happens. I know that the measurements on the leaflet were pretty much spot on.
gmham
Call Sign: 108TM154
Post by gmham » 29 May 2018, 19:35
Ok cheers Simon thanks again anyway.just waitting on my RG213u arriving anyway so maybe another gpe27 owner may have the answer before I get it up in the air !
108-TM-154 - John
Mudslinger
Post by Mudslinger » 29 May 2018, 19:52
Just had a look on the sirio website at the intruction manual, and you are meant to measure to just beneath the ball to the top of the collar. 562mm is the correct length for 27.5Mhz
That is what I set my one to and it worked straight off.
gmham
Call Sign: 108TM154
Post by gmham » 29 May 2018, 20:00
Perfect mate you've been very helpful appreciate that.
108-TM-154 - John
gmham
Call Sign: 108TM154
Post by gmham » 03 Jun 2018, 10:13
Here's a strange one Simon, I see the instructions supplied with the Sirio gpe27 have changed. I first noticed that now it clearly shows where you measure the distance from on the top tuning rod but more strangely the swr V freq chart has changed ?!
The newly updated instructions available online for the 5/8 wave version show the following freq v swr table :
26.4 mhz = 850mm for the 5/8 wave version.
27 mhz = 642mm
27.185mhz = 600mm
27.500mhz = 487mm
28.000mhz =340mm
28.500mhz =183mm
29.000mhz=15mm
The table supplied with my own Sirio gpe27 5/8 wave purchased from Nevada just weeks ago comes with a tuning table and was also showing online a few weeks ago as showing :
26.700mhz = 900mm
27.000mhz =816mm
27.185mhz =760mm
27.500mhz =664mm
28.000mhz =512mm
28.500mhz =354mm
29.000mhz =204mm
29.500mhz =54mm
So for instance 28.5 mhz shows a length off 183mm on one table and 354mm on the newer instructions.
Strange ???????!
108-TM-154 - John
Mudslinger
Post by Mudslinger » 07 Jun 2018, 11:39
The newer version has less sections, 5 plus the top bit.
It is the longer set of measurements you need.
gmham
Call Sign: 108TM154
Post by gmham » 08 Jun 2018, 08:20
Okay cheers Simon to be honest never knew there was a newer version ? how many sections did the older one have ? Sure paperwork for all versions showed five sections with just the tuning table being different ? Interestingly my one has five sections plus the tuning rod and came with the other shorter measurements ie.115mm for 28.5 ?
Still awaiting it being erected otherwise obviously could have answered my own question !!
108-TM-154 - John
prettypolly
Call Sign: 26FB185
Post by prettypolly » 08 Jun 2018, 08:31
So why has it got shorter ?? I have a gpa 5/8 s rod and its only 19.5 feet long very strange
gmham
Call Sign: 108TM154
Post by gmham » 08 Jun 2018, 12:01
Is it 19.5 in total with the tuning rod ? Does yours have the static ball at the top ?
108-TM-154 - John
Mudslinger
Post by Mudslinger » 08 Jun 2018, 21:05
They used to be 6 sections plus the tuning bit. Unfortunately mine is the shorter one, but it still seems to work very well.
gmham
Call Sign: 108TM154
Post by gmham » 09 Jun 2018, 16:56
Strangely enough spoke to tech advisor at Sirio antennas in Italy this week and he could not understand why two sets of instructions for this antenna ? I have just checked there website and I see its been changed back to the original instructions / original tuning table ?!
5/8wave " five section " + top tuning rod Sirio gpe27 pdf instructions :
http://www.sirioantenne.it/images/pdf/m ... id-037.pdf
108-TM-154 - John
