Cigar socket to run rig??
Eddie866
Call Sign: 26tm866
Post by Eddie866 » 02 May 2018, 15:02
Ok i have just got a anytone 6666 some manuals say 10amp draw some say 15amp draw , my quistion is
My socket in the car is marked 12v 120watts max
Can i run my rig pluged into it
The fuse in the glove compartment is rated at 20amp
Its nearly new car and would be dificult to run cables from engin bay to inside so looking at the easy way out
Metradio
Call Sign: G7HID
Re: Cigar socket to run rig??
Post by Metradio » 02 May 2018, 15:59
12v 120wwatt max =10amp max..
Would suggest you look at the size of the wire connecting the fuse box to the Cigar socket, I bet it is woefully thin !
Mike
Call Sign: n0call
Post by ch25 » 02 May 2018, 16:25
No fuse box inside? I would take + lead from there.
6666 and cigar socket can be dangerous.
Mudslinger
Post by Mudslinger » 02 May 2018, 16:33
Metradio wrote:
02 May 2018, 15:59
Mike
That is assuming that the radio is 100% efficient. It is likely to be around 50% efficient at best, especially if it has Mosfet outputs.
My KL-203p is meant to draw 10A max, but it is more like 16A
The Collector
Post by The Collector » 04 May 2018, 11:38
As above, run extra +/- cables from fuse box points or directly from the battery. You can drill a small hole and use a grommet to pass them through unless the car's under warranty or you just can't physically get a drill in. Ensure there's a rated fuse in-line regardless.
G8YMW
Post by G8YMW » 05 May 2018, 17:25
On my motor, there is ducting from the heater unit to the passenger side vent.
A grommet where it enters the cabin and has a rubber nipple.
That's where I'm diving in.
Another problem using the ciggie lighter (caused by the mileage and lack of gauge of the wire) is voltage sag under load.
This will cause FM-ing of the audio on ssb (distortion)
