Reducing power on ssb on superstar ss 9900
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 13:55
Hi all,can anyone tell me how to reduce the ssb output power on a ss9900 if I turn the dial fully down it's still doing over 50 watts.i want to turn it down to around 35 watts so it doesn't overdrive it all the time.
Regards
ROTEL240
Re: Reducing power on ssb on superstar ss 9900
Post by ROTEL240 » 05 Mar 2018, 14:47
Normally the pots are marked up i have backed off the echo delay and echo volume on my 9900 which are at the front of the board nr the channel knob so have a look inside for SSB PWR you will need a tiny cross head driver,i would also back the FM PWR right down as they are known for running very hot.Good luck..
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 16:34
Hi there,the FM was already turned down.it was just ssb I need to turn down a touch.thanks for the info.
Regards
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 20:47
Hi,all iv set up he ssb output to 40 watts high and its 5 watts on the he lowest. fm is set to 25 watts high and 1.5 lowest.thanks all.
Regards
ROTEL240
Post by ROTEL240 » 06 Mar 2018, 08:47
nice one were they labeled up,saves working the radio to hard and blowing the outputs.
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 06 Mar 2018, 10:58
Yes mate,it was easy to find,just near the ctss board.
ROTEL240
Post by ROTEL240 » 06 Mar 2018, 11:00
MrPaul009 wrote:
06 Mar 2018, 10:58
Thanks Paul :thumbup:
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 06 Mar 2018, 11:53
Hi,if anyone want to lower the power internally just watch the small vr screw.mine was very twitchy to setup.
Users browsing this forum: Macgiver and 6 guests
