Full wave loop for 11m
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 04 Mar 2018, 10:12
Hi all,has anyone built a full wave loop for 11m on here?also what is the Performance like compared to an inverted v dipole.im thinking in making one as a secondary antenna.also is there any companies out there make them for 11m
Regards
Call Sign: n0call
Re: Full wave loop for 11m
Post by ch25 » 04 Mar 2018, 10:34
Horizontal loop will have much higher radiation angle than inv V. Ground influence too.
If you can hang it vertically will be much better.
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 04 Mar 2018, 10:46
Hi there,and thanks for the reply,yes it will be hanging vertically from a 10m fiberglass flag pole.
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 04 Mar 2018, 13:14
Yes I made one a while ago, for 10m mind. It hung as a vertical triangle, apex up, spreader at the bottom with a 4:1 current balun at the centre, so it was about 3m/3m/3m
Tried it on the local net, but as they all just using verticals it wasn't that good and as the band is so quiet these days it didn't stay up long.
Best compromise antenna I've put up that would do 11m locally and decent UK/Europe ham was a simple inverted L with remote base tuner
MCAT
New User
New User
Call Sign: 163SC26
Post by MCAT » 04 Mar 2018, 18:06
I have one installed in my loft. It is mounted horizontally fed using a 4:1 balun. As noted in a previous reply, the angle of radiation on 10/11m band is very high. This makes it not too good for ground wave (which in my locale makes no difference to me). As for working sporadic E or F2 propagation it works OK. I have worked much of Western Europe and made a few. QSO's into South America. An advantage is however, it is a quieter antenna than many and does not suffer from too much QRN. It's an easy antenna to build without a balun using a 75ohm quarter wave tuning stub in lieu thereof.
If I were going to mount it vertically I would not use a full wave loop, a Quad loop or Delta loop would be a superior performer with the alternative of horizontal or vertical polarization depending on where the feed is positioned.
Hope this has been a help and tempted your curiosity.
73's
Mcatmick
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 04 Mar 2018, 18:35
Hi all and thanks for the information.anyone compared it to an inverted v?I think if I make one I will feed it at the bottom.
Regards
Tigersaw
Call Sign: GW6RRL
Post by Tigersaw » 04 Mar 2018, 18:45
The only other time I made a dedicated 10m antenna was a double bazooka, which is close to a dipole, I had it in the loft as inverted V.
It did very well, getting across to the states on FM, but that was a different year and so cant be compared to the delta loop described earlier.
It also worked on 6m as well to some degree, a bonus as it was not the intention.
prettypolly
Call Sign: 26FB185
Post by prettypolly » 05 Mar 2018, 15:43
the single element quad loop i make are very good ,they operate like 2 x 1/4 wave antennas i feed mine from the 3pm position or 9pm position there very quiet and very good on performance if you want il build you one for nothing etc as i have 2 or 2 knocking about..
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 05 Mar 2018, 16:39
Hi and thanks,that would be great if you would.
Regards
steepeljack69
Call Sign: 26SF333
Post by steepeljack69 » 08 May 2018, 15:24
I use a Mfj mag loop which is 4ft off ground on my rotator,I live really low down with hills 3 sides of me.its best antenna I have and works great on 11m as well as other bands it works on.
prettypolly
Call Sign: 26FB185
Post by prettypolly » 13 May 2018, 18:50
My little loop at 30 feet..
