Problem with antron 99
andrew013
Call Sign: 26AT013
Re: Problem with antron 99
Post by andrew013 » 03 Mar 2018, 09:57
ROTEL240 wrote: ↑
03 Mar 2018, 09:01
trying to check the Swr at the antenna end is a new one on me,
well you need to learn more on how to run a set up then
and just so you know testing at the antenna end or AS CLOSE IT AS POSSIBLE will give a more accurate reading of the swr once you have done that you can then check it at the radio end and see if it has alterd not that it will but it might do so on the meter due to length of coax or run of coax
have you not heard of cut an inch of your coax your swr will drop myth , there are some good books out there that teach you facts not fiction from your next door good buddy who got the info from a friend of a breaker in dip sh1teland from around the corner bar
ROTEL240
Post by ROTEL240 » 03 Mar 2018, 11:16
andrew013 wrote: ↑
03 Mar 2018, 09:47
ROTEL240 wrote: ↑
03 Mar 2018, 09:01
how do you check a mag mount at the antenna end.
dead easy chop the coax an inch from the antenna , :roll:
Brilliant I will buy I Β£40 trimag and chop the coax offπŸ™ˆπŸ˜‚πŸ˜‚. In 30 + years of swring in antennas I have never connected at the antenna end and no issues. πŸ˜€
andrew013
Call Sign: 26AT013
Post by andrew013 » 03 Mar 2018, 11:56
ROTEL240 wrote: ↑
03 Mar 2018, 11:16
andrew013 wrote: ↑
03 Mar 2018, 09:47
ROTEL240 wrote: ↑
03 Mar 2018, 09:01
whoop de whooo get yourself a blue peter badge
ROTEL240
Post by ROTEL240 » 03 Mar 2018, 12:26
andrew013 wrote: ↑
03 Mar 2018, 11:56
ROTEL240 wrote: ↑
03 Mar 2018, 11:16
andrew013 wrote: ↑
03 Mar 2018, 09:47
Thanks for the Blue peter badge, and you can have one if you can tell me how to SWR my antenna in 30ft up the pole {bnghd} :D
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 03 Mar 2018, 12:51
Hi again to all,just been out just to fine tune the t2lt now it's 1.5 channel 1 mid block, channel 40 uk fm it's 1.3.so the antron is going back for a replacement.thanks for the help guys,but I had a gut feeling there was something wrong when I tested it.still bloody cold here couldn't feel my hands messing around.
Regards
ROTEL240
Post by ROTEL240 » 03 Mar 2018, 12:58
Nice one,my faulty one was doing my head in and after a time you know something is not right after checking the coax and plugs,let us know how your new one performs mate .
andrew013
Call Sign: 26AT013
Post by andrew013 » 03 Mar 2018, 13:20
ROTEL240 wrote: ↑
03 Mar 2018, 12:26
andrew013 wrote: ↑
03 Mar 2018, 11:56
ROTEL240 wrote: ↑
03 Mar 2018, 11:16
no thanks thats your problem not mine you figure it out , i did , tho i did need 2 other people to give me a hand theres a tip for you by the way
Mudslinger
Post by Mudslinger » 03 Mar 2018, 13:29
You need a cordless SWR meter.
Call Sign: n0call
Post by ch25 » 03 Mar 2018, 13:44
Mudslinger wrote: ↑
03 Mar 2018, 13:29
Not really. He needs measurement cable length 180 degrees or it's multiplication. Even 75 Ohm :) It will be transparent for measurement device.
ROTEL240
Post by ROTEL240 » 03 Mar 2018, 14:46
ch25 wrote: ↑
03 Mar 2018, 13:44
Mudslinger wrote: ↑
03 Mar 2018, 13:29
Bang on just what I was thinking,swr at the the radio never had any issues so no need to complicate things. Now let me climb up this pole to check my swr which is lower than a rattlesnakes knackers at the radio endπŸ˜‚πŸ˜‚
MrPaul009
Call Sign: Fb009
Post by MrPaul009 » 03 Mar 2018, 15:54
Come on Calm down guys! I only started the thread off asking about a problem with a new antron.didnt want anyone to get into arguments over it.
astradyne
Moderator
Moderator
Post by astradyne » 03 Mar 2018, 16:58
Things really have been getting out of hand here guys. There's never any need for personal abuse aimed at other forum users no matter what the circumstances.
A couple of posts containing abusive language have been removed and the thread locked to avoid things escalating.
Keep it civil chaps! :D
Locked
