Spiderbeam/Spiderpole 12HD ADVICE NEEDED
WARLOCK
Call Sign: 26TM134
Post by WARLOCK » 04 Feb 2018, 19:37
I have just bought a Spiderpole 12HD fibraglass 12mt pole , Can anyone tell me will i need to tape the sections or will they stay up without tape and what is the best way to mount the pole and what to ??? it is to be used as a permident fixture with a doublet antenna on it .
ROTEL240
Re: Spiderbeam/Spiderpole 12HD ADVICE NEEDED
Post by ROTEL240 » 04 Feb 2018, 20:58
The sections will stay up but i would tape the joints up with duck tape for a pemanent install,
Call Sign: n0call
Post by ch25 » 04 Feb 2018, 21:20
For permanent I would use aluminium pipe. Top2-3 sections are too weak to hold wire antenna straight. Just wasted money.
Those spiderpoles are fine for temporary vertical build.
